2018-12-07 06:23:26.152 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2018-12-07 06:23:26.153 Info, Node003, SwitchMultilevel::Set - Setting to level 255
2018-12-07 06:23:26.153 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x26, 0x01, 0xff, 0x25, 0x2c, 0x37
2018-12-07 06:23:26.153 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x2d, 0xc8
2018-12-07 06:23:26.153 Info, Node003, Sending (Send) message (Callback ID=0x2c, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x26, 0x01, 0xff, 0x25, 0x2c, 0x37
2018-12-07 06:23:26.161 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-07 06:23:26.161 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-07 06:23:26.177 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x2c, 0x00, 0x00, 0x02, 0xc5
2018-12-07 06:23:26.177 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x2c received (expected 0x2c)
2018-12-07 06:23:26.177 Info, Node003, Request RTT 24 Average Request RTT 23
2018-12-07 06:23:26.178 Detail, Node003, Removing current message
2018-12-07 06:23:26.178 Info, Node003, Sending (Send) message (Callback ID=0x2d, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x2d, 0xc8
2018-12-07 06:23:26.186 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-07 06:23:26.186 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-07 06:23:26.202 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x2d, 0x00, 0x00, 0x02, 0xc4
2018-12-07 06:23:26.202 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
2018-12-07 06:23:26.202 Info, Node003, Request RTT 23 Average Request RTT 23
2018-12-07 06:23:26.213 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x01, 0xd6
2018-12-07 06:23:26.213 Info, Node003, Response RTT 35 Average Response RTT 35
2018-12-07 06:23:26.213 Info, Node003, Received SwitchMultiLevel report: level=1
2018-12-07 06:23:26.213 Detail, Node003, Refreshed Value: old value=0, new value=1, type=byte
2018-12-07 06:23:26.213 Detail, Node003, Changes to this value are not verified
2018-12-07 06:23:26.213 Detail, Node003, Expected reply and command class was received
2018-12-07 06:23:26.213 Detail, Node003, Message transaction complete
2018-12-07 06:23:26.213 Detail, Node003, Removing current message
2018-12-07 06:23:26.213 Detail, Node003, Notification: ValueChanged
2018-12-07 06:23:34.222 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 0
2018-12-07 06:23:34.222 Info, Node003, SwitchMultilevel::Set - Setting to level 0
2018-12-07 06:23:34.222 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x26, 0x01, 0x00, 0x25, 0x2e, 0xca
2018-12-07 06:23:34.223 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x2f, 0xca
2018-12-07 06:23:34.223 Info, Node003, Sending (Send) message (Callback ID=0x2e, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x26, 0x01, 0x00, 0x25, 0x2e, 0xca
2018-12-07 06:23:34.231 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-07 06:23:34.234 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-07 06:23:34.247 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x2e, 0x00, 0x00, 0x02, 0xc7
2018-12-07 06:23:34.247 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x2e received (expected 0x2e)
2018-12-07 06:23:34.247 Info, Node003, Request RTT 24 Average Request RTT 23
2018-12-07 06:23:34.247 Detail, Node003, Removing current message
2018-12-07 06:23:34.248 Info, Node003, Sending (Send) message (Callback ID=0x2f, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x2f, 0xca
2018-12-07 06:23:34.256 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-07 06:23:34.256 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-07 06:23:34.271 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x2f, 0x00, 0x00, 0x02, 0xc6
2018-12-07 06:23:34.271 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x2f received (expected 0x2f)
2018-12-07 06:23:34.271 Info, Node003, Request RTT 23 Average Request RTT 23
2018-12-07 06:23:34.283 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x5f, 0x88
2018-12-07 06:23:34.283 Info, Node003, Response RTT 35 Average Response RTT 35
2018-12-07 06:23:34.283 Info, Node003, Received SwitchMultiLevel report: level=95
2018-12-07 06:23:34.283 Detail, Node003, Refreshed Value: old value=1, new value=95, type=byte
2018-12-07 06:23:34.283 Detail, Node003, Changes to this value are not verified
2018-12-07 06:23:34.283 Detail, Node003, Expected reply and command class was received
2018-12-07 06:23:34.283 Detail, Node003, Message transaction complete
2018-12-07 06:23:34.283 Detail, Node003, Removing current message
2018-12-07 06:23:34.283 Detail, Node003, Notification: ValueChanged
2018-12-07 06:23:35.235 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x30, 0xd5
2018-12-07 06:23:35.235 Info, Node003, Sending (Send) message (Callback ID=0x30, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x30, 0xd5
2018-12-07 06:23:35.243 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-07 06:23:35.243 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-07 06:23:35.259 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x30, 0x00, 0x00, 0x02, 0xd9
2018-12-07 06:23:35.259 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x30 received (expected 0x30)
2018-12-07 06:23:35.259 Info, Node003, Request RTT 24 Average Request RTT 23
2018-12-07 06:23:35.271 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x3e, 0xe9
2018-12-07 06:23:35.271 Info, Node003, Response RTT 35 Average Response RTT 35
2018-12-07 06:23:35.271 Info, Node003, Received SwitchMultiLevel report: level=62
2018-12-07 06:23:35.271 Detail, Node003, Refreshed Value: old value=95, new value=62, type=byte
2018-12-07 06:23:35.271 Detail, Node003, Changes to this value are not verified
2018-12-07 06:23:35.271 Detail, Node003, Expected reply and command class was received
2018-12-07 06:23:35.271 Detail, Node003, Message transaction complete
2018-12-07 06:23:35.271 Detail, Node003, Removing current message
2018-12-07 06:23:35.271 Detail, Node003, Notification: ValueChanged
2018-12-07 06:23:36.247 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x31, 0xd4
2018-12-07 06:23:36.247 Info, Node003, Sending (Send) message (Callback ID=0x31, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x31, 0xd4
2018-12-07 06:23:36.256 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-07 06:23:36.256 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-07 06:23:36.271 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x31, 0x00, 0x00, 0x02, 0xd8
2018-12-07 06:23:36.271 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x31 received (expected 0x31)
2018-12-07 06:23:36.271 Info, Node003, Request RTT 23 Average Request RTT 23
2018-12-07 06:23:36.282 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x1c, 0xcb
2018-12-07 06:23:36.283 Info, Node003, Response RTT 35 Average Response RTT 35
2018-12-07 06:23:36.283 Info, Node003, Received SwitchMultiLevel report: level=28
2018-12-07 06:23:36.283 Detail, Node003, Refreshed Value: old value=62, new value=28, type=byte
2018-12-07 06:23:36.283 Detail, Node003, Changes to this value are not verified
2018-12-07 06:23:36.283 Detail, Node003, Expected reply and command class was received
2018-12-07 06:23:36.283 Detail, Node003, Message transaction complete
2018-12-07 06:23:36.283 Detail, Node003, Removing current message
2018-12-07 06:23:36.283 Detail, Node003, Notification: ValueChanged
