Hello guys!
Thank you for the welcome and posts!
Checking out ih8gates’ dimmer switch.
PtP,
Thank you for the congrats!
It’s my first home and I am super excited.
Re-wiring everything up, and got a couple of things lined-up.
For example, the house has an “intercom” system between rooms and 1st and 2nd floor: I am thinking of pulling that original cabling out, and installing Cat5e cable inside.
That will help me have a better network throughout the house (I love Mikrotik equipment, and I have various Mikrotik RB951 units that receive PoE, so with one cable, there will be a wifi spot).
I am trying to nail down everything I can, as we pulled up all the tiles of the floor, and we are about to start installing the new tiles (concrete floor).
I already laid out a 1" PVC pipe to pull the gas line through, and change the house to gas stove instead of electric.
I am also laying out a 1-1/2" PVC pipe that will go from the main breaker panel, to the location in the patio where the emergency generator will be located. Better to do all this now than later (although I still won’t be buying the generator).
PtP, the multiple Pis, I was thinking of installing “motion” on various of them, and have them as “security cameras”.
Either install raspbian with motion, or install “motioneyeos” full.
Another Pi I want to use for music: I have a DAC board, to give it good audio output.
Just setting up some cool stuff.
I think I have a better direction now.
Setting up Home Assistant in a machine (what do you think about a Pi versus a laptop? Difference in performance of Home Assistant itself?).
Various simple dimming LED bulbs for things like the house entrance, sides and backyard.
And inside, a couple (they’re COSTLY!) Philips Hue bulbs.
Throwing some ideas out there… what do you think?
