Generate response based on IFTTT intent
I have setup my broadlink RM Mini 3 and have successfully got it to work with IFTTT to turn on/off the tv.
I have the numbers of the TV remove configured with the broadlink / I have the hex codes for them.
Is there anyway I can have IFTTT work with these by joining them up.
For example if I say “Okay Google, Channel 25”, it will send that over to a script that will take the numbers 2 and 5 and add together the RF codes for those numbers and transmit that?
You can create a script in HA and trigger the script in IFTTT. That’s what I’m doing.
