I have an automation that takes a snapshot of my 3D printer camera at the end of the print and saves it with a sequential number.
I would like to set up a lovelace card where the click action opens the most recent photo in a new tab.
My idea was to have the automation increment a counter, and then I would append that counter value onto the local url for the media folder.
The code for the card is as follows:
tap_action:
action: url
url_path: |
/local/printercam/capture_{{states.input_number.counter.state}}.jpg
This does not insert the input number into the string, but rather opens a new tab with that exact url.
However, entering
into the template editor returns the correct url.
Is there other formatting that I need to use when templating the string?
Most Dashboard cards do not support templates at all, and even fewer support them in Card actions.
mirekmal
(Mirek Malinowski)
3
Just use markdown card for this:
type: markdown
content: |
<a href="/local/printercam/capture_{{states.input_number.counter.state}}.jpg" target="_blank">Open image</a>
You can also change this to for example display just some icon, instead of text, to make it more ‘button like’:
type: markdown
content: |
<a href="/local/printercam/capture_{{states.input_number.counter.state}}.jpg" target="_blank"><ha-icon icon="mdi:link-variant"></ha-icon></a>
Troon
(Troon)
4
Right at the bottom of the Actions page:
Also, use {{ states('input_number.counter') }}: see the warning at the end of this section:
Rudd-O
(Rudd-O)
5
Also consider
You can then add a camera view card and, when the file changes, the view updates.
