Generic-bk7231n-qfn32-tuya WRGB light incorrect colour on bootup
I have hacked a Costco set of lights to move from Tuya to ESPHome.
This works great, but I get a weird bug… when the device is first turned on the colour is bright white even when turned off.
Then when I turn to a colour the white lights are still on, so greens look very pale.
Finally if I change (via HA) the lights to White and then back to RGB, it fixes it.
I am looking at a way to do this using the on_boot process… The current logic below does not work & I don’t know enough about ESPHome to know why its doing it & how to fix it.
esphome:
  friendly_name: IvysLEDs
  comment: Ivy's LED Lights
  on_boot:
    priority: 600.0
    then:
      - light.turn_on:
          brightness: 100%
          white: 100%
      - delay: 5 seconds
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
      - delay: 5 seconds
      - light.turn_off: light_rgbw
bk72xx:
  board: generic-bk7231n-qfn32-tuya
# Enable logging
logger:
mdns:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  - platform: esphome
    password: ""
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Fallback Hotspot"
    password: ""
captive_portal:
text_sensor:
  - platform: libretiny
    version:
output:
  - platform: libretiny_pwm
    pin: P9
    pin: P8
    pin: P7
    pin: P6
light:
  - platform: rgbw
    red: output_red
    green: output_green
    blue: output_blue
    white: output_cold
    color_interlock: true
    default_transition_length: 0.25s
    effects:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
      - pulse:
          # transition_length: 1s
          # defaults to 1s
          update_interval: 2s
      - pulse:
          transition_length:
            on_length: 1s
            off_length: 500ms
          update_interval: 1.5s
      - random:
          name: Random Effect With Custom Values
          transition_length: 5s
          update_interval: 7s
Am I missing something?
As I say if I Change in HA to white and then to RGB it works fine… it is just on that first boot… which is a little annoying as ideally it would remember that my daughter likes it full green :smiley:
