Hi to everybody, I added camera with Generic Camera integration, I use telegram command to send a snapshot as a request. The problem that 1 attempt from 3-5 successfull, all the rest have an error Timeout(code provided below) even if I request snapshot service manually.
By the way with ONVIF integration all snapshots is successfull. Please help to resolve a problem.
2024-04-04 23:04:42.636 ERROR (MainThread) [homeassistant.components.automation.novaia_avtomatizatsiia111_2] Telegram_menu: Choose at step 1: Камеры: Error executing script. Unexpected error for call_service at pos 2:
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 1017, in async_handle_snapshot_service
await _async_get_stream_image(camera, wait_for_next_keyframe=True)
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 238, in _async_get_stream_image
return await camera.stream.async_get_image(
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 565, in async_get_image
return await self._keyframe_converter.async_get_image(
File "/usr/src/homeassistant/homeassistant/components/stream/core.py", line 539, in async_get_image
await self._event.wait()
File "/usr/local/lib/python3.12/asyncio/locks.py", line 212, in wait
await fut
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 504, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 733, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 696, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2542, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2579, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 971, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1043, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 1015, in async_handle_snapshot_service
async with asyncio.timeout(CAMERA_IMAGE_TIMEOUT):
File "/usr/local/lib/python3.12/asyncio/timeouts.py", line 115, in __aexit__
raise TimeoutError from exc_val
TimeoutError
2024-04-04 23:04:42.645 ERROR (MainThread) [homeassistant.components.automation.novaia_avtomatizatsiia111_2] Telegram_menu: Error executing script.
Unexpected error for choose at pos 1:
await fut
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 954, in _async_choose_step
await self._async_run_script(script)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1139, in _async_run_script
result = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1650, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 454, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 506, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 536, in _handle_exception
raise exception
result = await task
TimeoutError
2024-04-04 23:04:42.694 ERROR (MainThread) [homeassistant.components.automation.novaia_avtomatizatsiia111_2] While executing automation automation.novaia_avtomatizatsiia111_2
await fut
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 726, in async_trigger
return await self.action_script.async_run(
raise exception
raise exception
result = await task
TimeoutError
UPD: I used FFMPEG configuration via configuration.yaml using personal RTSP URL and the problem have been resolved.
