I use two input_numbers to set the temperature I want my ceiling fans to turn on and turn off at. I when the temperature sensor in that room reaches the high temp, it HA turns on the ceiling fan. When the temp gets below the low temp, it turns off the ceiling fan. Rather than have the two input sliders, I would like a gauge like control or thermostat like control that isn’t tied to a particular domain. My ceiling fans and input_numbers obviously aren’t a climate type entity so thermostats don’t work for them. gauge would be an option, but I think it only shows one value, and it’s read only.
Can you make a climate device with this?
Seems to be what I need. It doesn’t show up in edit mode correctly under lovelace, but it looks fine in normal mode. It would be nice if the configuration settings could be set via lovelace config instead of having to put them in the component under HA. But it should do. Thanks
