First of all, thank you very much to everybody reads this post! Thank you very much awesome home assistant community!
I’m configuring my generic thermostat.
This is the standard configuration (and it works pretty well):
#### AC living room
climate:
- platform: generic_thermostat
name: AC living room
unique_id: AC_living_room
heater: input_boolean.ac_living_room
target_sensor: sensor.living_room_temperature
min_temp: 18
max_temp: 35
ac_mode: true
min_cycle_duration:
minutes: 5 ### <- I'M WORKING ON THIS VALUE
cold_tolerance: 5 ### <- I'M WORKING ON THIS VALUE
hot_tolerance: 5 ### <- I'M WORKING ON THIS VALUE
initial_hvac_mode: "off"
I would like to be able to easily control three values (without changing my configuration.yaml):
- min_cycle_duration
- cold_tolerance
- hot_tolerance
In order to be able to control those three values I’ve created three number helpers:
- input_number.ac_living_room_min_cycle_duration
- input_number.ac_living_room_cold_tolerance
- input_number.ac_living_room_hot_tolerance
Then I tried to change my configuration.yaml as follows:
#### AC living room
climate:
min_temp: 18
max_temp: 35
ac_mode: true
min_cycle_duration:
minutes: "{{ states('input_number.ac_living_room_min_cycle_duration') | float }}"
cold_tolerance: "{{ states('input_number.ac_living_room_cold_tolerance') | float }}"
hot_tolerance: "{{ states('input_number.ac_living_room_hot_tolerance') | float }}"
Unfortunately it doesn’t work: when I check my configuration.yaml, home assistant tells me that the three values above (min_cycle_duration, cold_tolerance and hot_tolerance) expect a float value.
Any idea?
Thank you very much to everybody wants to help me!!
PD: I tried to write this post in the simplest way possible, so that I hope that my problem is easily understandable; if I couldn’t explain myself properly, I apologise (I’m italian), and I’ll provide further details!
Thank you
Andrea
