Generic thermostat and Google Assistant
I often use generic thermostats as integer variables as you can use Google to set the values with your voice. However, recently I just discovered that sometimes Google won’t change the value of the thermostat to the number I specified. In fact I can only set my thermostat between 50 and 60 degrees.
Anything outside of that and I get a
ThermostatName can’t be set to that temperature.
I can manually change it in HA, but not from Google. Any idea as to what’s the problem?
