Generic Tuya Smart Vacuum (Eufy, Ionvac) ESPHome Config
Sharing my ESPHome configurations for the Eufy RoboVac 30C and Tzumi Ionvac SmartClean 2000, which are based on the Tuya wifi module. There may be room for improvement. Guessing several generic vacuums will have similar configuration files.
Eufy Robovac 30C
ESP8266EX
TYWE1S Module
esphome:
  friendly_name: ESPHome RoboVac 30C
  min_version: 2025.11.0
  name_add_mac_suffix: false
  on_boot:
    priority: 800
    then:
      - delay: 5s
      - logger.log: "MCU Waiting for heartbeat..."
esp8266:
  board: esp01_1m
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: Eufy-Robovac Fallback Hotspot
    password: Redacted
captive_portal:
web_server:
# Tuya supports sending time to the application processor and the vacuum does use it (not sure for why though) so let's configure a time reference
time:
  - platform: homeassistant
# UART will be used to talk to the application processor, so we need to disable any logging over it
logger:
  baud_rate: 0
# UART to talk to the application processor
uart:
  rx_pin: GPIO13
  tx_pin: GPIO15
  baud_rate: 115200
  debug: null
# the TuyaMCU object
tuya:
  uart_id: vacuum_uart
  time_id: time_source
  - platform: tuya
    sensor_datapoint: 104
    unit_of_measurement: "%"
    icon: mdi:battery
    device_class: battery
    state_class: measurement
    entity_category: diagnostic
button:
    entity_category: config
    on_press:
      - lambda: id(vacuum_tuya).force_set_enum_datapoint_value(5, 0);
    name: Start spot cleaning
    on_press:
      - lambda: id(vacuum_tuya).force_set_enum_datapoint_value(5, 2);
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(2, false);
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(2, true);
    name: Return to dock
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(101, true);
    on_press:
      - lambda: id(vacuum_tuya).force_set_enum_datapoint_value(3, 0);
    on_press:
      - lambda: id(vacuum_tuya).force_set_enum_datapoint_value(3, 1);
    on_press:
      - lambda: id(vacuum_tuya).force_set_enum_datapoint_value(3, 2);
    on_press:
      - lambda: id(vacuum_tuya).force_set_enum_datapoint_value(3, 3);
select:
  - platform: tuya
    enum_datapoint: 3
    options:
      0: "Forward"
      1: "Back"
      2: "Right"
      3: "Left"
  - platform: tuya
    enum_datapoint: 5
    options:
      0: Auto
      1: Edge
      2: Spot
      3: Small Room
  - platform: tuya
    enum_datapoint: 15
    options:
      0: Running
      1: Idle
      2: Sleeping
      3: Charging
      4: Charged
      5: Docking
    on_value: &publish_state_sensor
      then:
        - text_sensor.template.publish:
            state: !lambda 'return (id(pause_dp).state == "Paused" && id(status_dp).state == "Idle") ? "Paused" : id(status_dp).state;'
  - platform: tuya
    enum_datapoint: 102
    options:
      0: Standard
      1: BoostIQ
      2: Max
  - platform: tuya
    enum_datapoint: 2
    options:
      0: Paused
      1: Resume
    on_value: *publish_state_sensor
text_sensor:
  - platform: tuya
    sensor_datapoint: 106
    icon: mdi:alert-circle
switch:
  - platform: tuya
    icon: mdi:map-marker
    switch_datapoint: 103
  - platform: tuya
    switch_datapoint: 2
    icon: mdi:power
RTL8710BN
WR3 Module
I had to use the framework 1.9.2 to overcome a LibreTiny bug in the RX communication from the MCU. It may be fixed in more recent versions of ESPHome.
esphome:
  friendly_name: ESPHome SmartClean 2000
rtl87xx:
  board: wr3
  framework:
    version: 1.9.2
api:
ota:
  - platform: esphome
wifi:
  ap:
    ssid: Esphome-Smartclean Fallback
    password: "Redacted"
captive_portal:
web_server:
time:
logger:
  baud_rate: 0
uart:
  tx_pin: PA23
  rx_pin: PA18
  baud_rate: 115200
  debug: null
tuya:
  - platform: tuya
    sensor_datapoint: 6
    icon: mdi:battery
  - platform: tuya
    name: Clean Time Last
    sensor_datapoint: 17
    unit_of_measurement: minutes
    icon: mdi:timer-sync
    device_class: duration
    state_class: total_increasing
  - platform: tuya
    name: Clean Time Total
    sensor_datapoint: 108
  - platform: tuya
    name: Use Side Brush
    sensor_datapoint: 7
    icon: mdi:broom
  - platform: tuya
    name: Use Main Brush
    sensor_datapoint: 8
    icon: mdi:broom
  - platform: tuya
    sensor_datapoint: 9
    icon: mdi:air-filter
button:
# Not working
    name: Reset side brush
    icon: mdi:broom
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(10, true);
# Not working
    name: Reset main brush
    icon: mdi:broom
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(11, true);
# Not working
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(12, true);
    on_press:
    on_press:
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(2, 0);
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(2, 1);
    on_press:
      - lambda: id(vacuum_tuya).force_set_boolean_datapoint_value(3, 5);
select:
  - platform: tuya
    enum_datapoint: 3
    options:
      0: Standby
      1: Auto
      2: Edge
      3: Spot
      4: PartialBow
      5: Dock
  - platform: tuya
    enum_datapoint: 4
    options:
      0: "Forward"
      1: "180"
      2: "Left"
      3: "Right"
      4: "Stop"
  - platform: tuya
    enum_datapoint: 5
    options:
      0: Idle
      1: Charging
      2: Running
      3: Docking
      4: Fault
      9: Docked
      then:
  - platform: tuya
    enum_datapoint: 2
    options:
      1: Paused
      2: Resume
  - platform: tuya
    enum_datapoint: 14
    options:
      1: Normal
      2: Strong
text_sensor:
switch:
  - platform: tuya
    switch_datapoint: 2
    icon: mdi:power
  - platform: tuya
    switch_datapoint: 13
Thanks to Rjevski for his config esphome-eufy-robovac-g10-hybrid.
How did you flash the realtek wr3 module?
It has to be desoldered, right?
