I have been struggling with access to GitHub from a Generic x86 install on which I am running HA on an SSD. This is what I see when I run ping
from Terminal
In case I had done something stupid at the system level I made a fresh SD card using these instructions and set the BIOS to boot from the SD card first. I then set the user to Advanced Mode
and installed Terminal
. As you can see from the screenshot below, I did not install any other add-ons. I get the same result: I can ping other websites, but not GitHub.
Are there some other settings that I am missing? I cannot see anything in the instructions?
I’d really appreciate a quick response because I need some HACS updates.
Here is the raw system health report for the original install on the SSD.
System Health
version: core-2022.6.5
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.12
os_name: Linux
os_version: 5.15.41
arch: x86_64
timezone: Europe/Lisbon
logged_in: true
subscription_expiration: 14 June 2022, 01:00
relayer_connected: true
remote_enabled: true
remote_connected: true
alexa_enabled: false
google_enabled: true
remote_server: eu-central-1-2.ui.nabu.casa
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 8.1
update_channel: stable
supervisor_version: supervisor-2022.05.3
agent_version: 1.2.1
docker_version: 20.10.14
disk_total: 116.7 GB
disk_used: 29.7 GB
healthy: true
supported: true
board: generic-x86-64
supervisor_api: ok
version_api: ok
installed_addons: Samba share (9.6.1), Home Assistant Google Drive Backup (0.108.2), Check Home Assistant configuration (3.10.2), Terminal & SSH (9.4.0), Network UPS Tools (0.11.0), Samba Backup (5.0.0), Mosquitto broker (6.1.2), Studio Code Server (5.1.0)
api_endpoint_reachable: ok
dashboards: 7
resources: 7
mode: storage
oldest_recorder_run: 6 June 2022, 19:58
current_recorder_run: 13 June 2022, 13:31
estimated_db_size: 1994.88 MiB
database_engine: sqlite
database_version: 3.34.1
