Get friendly_name from his own sensor in a template
Hi All,
I have 209 sensors like this first one. Now try to shorten the rest of them as show below 2.
This is working. Only this I need is to repeat the attributes part, but must replace the ‘KMD’ part with unique codes:
    eur_kmd_test:
      value_template: "ok"
      friendly_name: "KMD"
      <<: &CRYPTO_ATTR_TEMPLATE
        attribute_templates:
          buy: >-
            {% set item =  state_attr('sensor.bitladon_all', 'result') | selectattr('ticker', 'eq', 'KMD') | first %}
            {{ item.buy }}
          sell: >
            {{ item.sell }}
          change24h: >-
            {{ item.change24h }}
          volume24h: >-
            {{ item. volume24h }}
    eur_gvt_test:
      friendly_name: "GVT"
      <<: * CRYPTO_ATTR_TEMPLATE
    eur_ftt_test:
      friendly_name: "FTT"
Idea is to replace the ‘KMD’ with a code that read the friendly_name of each sensor. So then every sensor will get the right code based on the friendly_name. But I really don’t know how to add this. This was working:
{% set item =  state_attr('sensor.bitladon_all', 'result') | selectattr('ticker', 'eq', state_attr('sensor.eur_kmd', 'friendly_name')) | first %}
{{ item.buy }}
Only thing the sensor.eur_kmd is coded hard. That is not the solution.
Cheers,
