is there a way to get the from_state in a template sensor?
sensors:
In automation this is possible with trigger.from_state. This fails in template sensors.
Any ideas?
sensors:
Any ideas?
Would remove the need for something like that:
alias: 'Steuerung: Temperaturänderung Norden'
description: ''
- platform: state
entity_id: sensor.aussen_norden_temperatur
condition: []
- choose:
- conditions:
- condition: state
entity_id: input_boolean.norden_steigt
state: 'on'
- condition: template
value_template: >-
{{ trigger.to_state.state | float < trigger.from_state.state |
float }}
sequence:
- service: input_boolean.turn_off
data: {}
- service: notify.telegram
message: 'Norden fällt {{ trigger.to_state.state }}'
- conditions:
- condition: state
state: 'off'
value_template: >-
{{ trigger.to_state.state | float > trigger.from_state.state |
float }}
sequence:
data: {}
message: 'Norden steigt {{ trigger.to_state.state }}'
default: []
mode: single
Could be done in a âone-linerâ in a template sensor.
It just detects if a temperature is rising or falling.
You could use a derivative sensor, derivative < 0 -> temperature is falling, derivative > 0 temperature is rising.
Cool! That looks great. Lemme thing about that.
Ok!
- platform: derivative
source: sensor.aussen_norden_temperatur
name: AuĂen Norden Temperaturänderung
source: sensor.aussen_sueden_temperatur
name: AuĂen SĂźden Temperaturänderung
But now I got an attribute of an entity I want to derive from.
Do I need to create a template sensor for the attribute and to create a derive sensor from that or can I do it in one step?
And is there a way to set the entity name (different from the autocreated name)?
You need to create a template sensor first that extracts the attribute.
Change the name in the sensor config to the name you would like to have for the entity_id. Then change the friendly name through customization.
