Get_hass_config() error in Appdaemon
I’ve a few AppDaemon apps running but I can’t seem to get the get_hass_config() call working. The following code snippet just doesn’t work:
import appdaemon.plugins.hass.hassapi as hass
class Test(hass.Hass):
    def initialize(self):
        self.log( 'test started' )
        config = self.get_hass_config()
When it runs I get the following error:
2018-12-19 10:48:09.411789 INFO test: test started
2018-12-19 10:48:09.411947 WARNING AppDaemon: ------------------------------------------------------------
2018-12-19 10:48:09.412084 WARNING AppDaemon: Unexpected error running initialize() for test
2018-12-19 10:48:09.412202 WARNING AppDaemon: ------------------------------------------------------------
2018-12-19 10:48:09.412476 WARNING AppDaemon: Traceback (most recent call last):
  File "/usr/local/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 1581, in init_object
    init()
  File "/conf/apps/test/test.py", line 8, in initialize
AttributeError: 'Test' object has no attribute 'get_hass_config'
2018-12-19 10:48:09.412603 WARNING AppDaemon: ------------------------------------------------------------
The documentation ([https://appdaemon.readthedocs.io/en/latest/HASS_API_REFERENCE.html#get-hass-config]) shows the call but, looking at the source code, it doesn’t appear anywhere in the hassapi.py file. I’m running the latest appdaemon in a docker container under Ubuntu. Any idea what I’m doing wrong?
Thanks in advance,
Steve
your not doing anything wrong.
get_hass_config has been changed to get_plugin_config and it isnt changed it the docs.
ill tell andrew to change it.
That works great,
Thanks!
