Get message from a telegram bot
Hi everyone,
im very new to home assistant, so i hope the topic is on right section.
I read a few guides, but not really understand how the telegram integration is working.
I have an existing telegram bot, which is sending “alarms”(text message) to myself. Now i want to trigger events in my smart home, when a “alarm” is generated from the bot.
I understand, that the “polling” is the easiest way to simple get messages, so i configured this to my configuration.yaml:
#telegram
telegram_bot:
  • platform: polling
    api_key: “API_KEY”
    allowed_chat_ids:
    • 1XXXX
There is no “Group_ID” in my conversation with the Bot, so i dont really understand, why this is needed?
Does it work this way or am i completly wrong?
Thank you!
This is my Telegram config. No group ID involved in the definition of that bot, because I don’t use a group chat with it.
I’m not sure where you seeing that a group ID is required.
There is no reference to “Group_ID” in the telegram bot polling documents, so not sure what you are referring to exactly?
Here is the docs:
For what it’s worth, telegram bot is much more easily and flexibly implemented using Node-Red, with better integration to HA.
I started off with HA’s native integrations, got frustrated at the lack of some message data, went to Node-Red and never turned back.
