Hi Everyone,
I am using Power-Switches from Gude for my IT Rack. I figured out how to switch this via Modbus. This works very well. Here is the code I am using:
modbus:
- name: "Expert Power Control 8041-1"
type: tcp
host: IP-ADRESS
port: 502
switches:
- name: gude1.port01
address: 0
write_type: coil
verify:
- name: gude1.port02
address: 1
write_type: coil
verify:
- name: gude1.port03
address: 2
write_type: coil
verify:
- name: gude1.port04
address: 3
write_type: coil
verify:
- name: gude1.port05
address: 4
write_type: coil
verify:
I know that Gude also can measure the Power of the Ports and also the overall Power. I found another topic here using MQTT. However I want to use the Modbus. Anyone did that before?
