My setup: I have both integrations for SmartThings:
- Climate IP (GitHub - atxbyea/samsungrac: Home Assistant Climate Device for controlling (not only) Samsung AC) integration and
- Official SmartThings (SmartThings - Home Assistant) integration.
I like more the Climate IP integration as it works with my Samsung EHS heating pump, instead of Official SmartThings integration that lacks many features.
[Breaking News] Official SmartThings integration started working with OAuth tokens (refreshed automatically) from HA core version 2025.3.0!
This means the access_token is available somewhere in HA and (maybe?) can be used by Climate IP also, instead of setting it in configuration.yaml file.
I found that it is stored in config/.storage/core.config_entries, under same entry with the same ID and it is changed/refreshed regularly.
It looks like this:
"created_at": "2025-03-05T18:53:59.335589+00:00",
"data": {
"auth_implementation": "cloud",
"location_id": "abcdefgh-20aa-4065-b572-6acae74b68ba",
"old_data": {
"access_token": "abcdefgh-71fd-413a-a502-086648767ca3",
"app_id": "abcdefgh-4645-4993-a502-46b45baecac4",
"client_id": "abcdefgh-bfd3-432a-ad50-7c788cd3a654",
"client_secret": "abcdefgh-ea4d-4773-8ec2-83e684d9586e",
"installed_app_id": "abcdefgh-aebf-4da4-9f22-b3428c3802ac",
"refresh_token": "abcdefgh-2d58-4139-b9cf-6cc79401627a"
"token": {
"access_tier": 0,
"access_token": "abcdefgh-49ea-4da0-b993-50a3bc4f069c",
"expires_at": 1741417499.9367576,
"expires_in": 86399,
"installed_app_id": "abcdefgh-6840-4fd8-8107-a6a0ddab6c8b",
"refresh_token": "abcdefgh-7ab7-4328-88e8-ddeb36a83ff1",
"scope": "r:hubs:* r:locations:* r:rules:* r:scenes:* x:devices:* sse w:rules:* w:locations:* w:devices:* r:devices:* x:locations:* x:scenes:*",
"service": "smartthings",
"token_type": "bearer"
"disabled_by": null,
"discovery_keys": {},
"domain": "smartthings",
"entry_id": "01JNKTGMN74E2EH6JA5G8E184E",
"minor_version": 1,
"modified_at": "2025-03-07T07:05:01.170242+00:00",
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "user",
"subentries": [],
"title": "My home",
"unique_id": "abcdefgh-20aa-4065-b572-6acae74b68ba",
"version": 3
As we all know, Climate IP integration has since 2025 the token issue - it works only with PAT tokens from SmartThings account and it has to be issued and manually changed daily.
Is there a way to change the code to grab programmatically the working access_token that is available from official SmartThings integration in core.config_entries file?
I’ve experimented with manually getting the token from there and setting it in the configuration.yaml file.
And Climate IP works with it, instead of going to SmartThings website and generating a new PAT token each day…
What we need to get in the code is this information (mind the values below, they are just examples from my setup):
"token": { "access_token": "abcdefgh-49ea-4da0-b993-50a3bc4f069c"...
Calling it by the "entry_id": "01JNKTGMN74E2EH6JA5G8E184E"
I am not a skilled developer for this kind of job, just a newbie
Is somebody here that can fork the samsungrac code with this idea?
Requires installing also the SmartThings official integration
Thanks a lot!
