I got a few M5 Atom Echos running. I also linked one to my Google Home Mini in the Office as an external speaker.
As I don’t have an Alexa or Google Home in my living room, I want to send the response as a notification text to my LG TV.
I just don’t know how to grab the response text. Is there a special entity or attribute for this?
mchk
May 4, 2025, 6:22pm
2
on_tts_start (Optional, Automation): An automation to perform when the voice assistant has started text-to-speech.
The text to be spoken is available to automations as the variable x.
Thank you for your help.
I saw my mistake: I added the notification to the on_tts_end part and was wondering why I got the the path of the .wav file as a response.
After adding it to on_tts_start it works fine!
Just in case somebody needs it, here is my code. Simply edit your API KEY, OTA Password, notification device and external media player:
substitutions:
friendly_name: Atom Echo Wohnzimmer
micro_wake_word_model: okay_nabu # alexa, hey_jarvis, hey_mycroft are also supported
esphome:
name_add_mac_suffix: true
friendly_name: ${friendly_name}
min_version: 2025.2.0
esp32:
board: m5stack-atom
framework:
type: esp-idf
version: 4.4.8
platform_version: 5.4.0
#version: latest
#platform_version: latest
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: YOUR API KEY
ota:
- platform: esphome
password: YOUR PASSWORD
wifi:
ssid: !secret wifi_ssid
captive_portal:
globals:
- id: tts_text
type: std::string
restore_value: no
initial_value: ""
button:
- platform: factory_reset
i2s_audio:
- id: i2s_audio_bus
i2s_lrclk_pin: GPIO33
i2s_bclk_pin: GPIO19
microphone:
- platform: i2s_audio
i2s_din_pin: GPIO23
adc_type: external
pdm: true
speaker:
i2s_dout_pin: GPIO22
dac_type: external
bits_per_sample: 32bit
channel: right
buffer_duration: 60ms
media_player:
- platform: speaker
announcement_pipeline:
speaker: echo_speaker
format: WAV
codec_support_enabled: false
buffer_size: 6000
volume_min: 0.4
files:
- id: timer_finished_wave_file
file: https://github.com/esphome/wake-word-voice-assistants/raw/main/sounds/timer_finished.wav
on_announcement:
- if:
condition:
- microphone.is_capturing:
then:
- if:
condition:
lambda: return id(wake_word_engine_location).state == "On device";
then:
- micro_wake_word.stop:
else:
- voice_assistant.stop:
- script.execute: reset_led
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: none
on_idle:
- script.execute: start_wake_word
text:
# Text configuration to se the media player you want to use for the assistant voice.
name: "Assistant Media Player"
entity_category: CONFIG
initial_value: media_player.valhalla_gh #YOUR MEDIA PLAYER
# Saves and loads the state to RTC/Flash
restore_value: true
mode: text
optimistic: true
voice_assistant:
microphone: echo_microphone
media_player: echo_media_player
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 2.0
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
effect: "Slow Pulse"
on_stt_vad_end:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
effect: "Fast Pulse"
on_tts_start:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: none
- homeassistant.service:
service: notify.lg_webos_tv_nano866pa #YOUR DEVICE TO NOTIFY
message: !lambda "return x;"
#speaker: !remove
on_tts_end:
# Call the media player as a service. You need to configure the device in the ESPHome integration to
# "Allow the device to perform Home Assistant actions".
service: media_player.play_media
entity_id: !lambda "return id(assistant_media_player).state.c_str();"
media_content_id: !lambda "return x;"
media_content_type: music
announce: "true"
- light.turn_off: led
on_end:
- delay: 100ms
on_error:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 100%
effect: none
- delay: 2s
on_client_connected:
- delay: 2s # Give the api server time to settle
on_client_disconnected:
on_timer_finished:
- wait_until:
not:
- switch.turn_on: timer_ringing
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 100%
- wait_until:
- switch.is_off: timer_ringing
- switch.turn_off: timer_ringing
binary_sensor:
# button does the following:
# short click - stop a timer
# if no timer then restart either microwakeword or voice assistant continuous
- platform: gpio
pin:
number: GPIO39
inverted: true
disabled_by_default: true
entity_category: diagnostic
on_multi_click:
- timing:
- ON for at least 50ms
- OFF for at least 50ms
then:
- if:
condition:
switch.is_on: timer_ringing
then:
else:
- timing:
- ON for at least 10s
then:
- button.press: factory_reset_btn
light:
- platform: esp32_rmt_led_strip
entity_category: config
pin: GPIO27
default_transition_length: 0s
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:
- pulse:
transition_length: 250ms
update_interval: 250ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
script:
- id: reset_led
then:
- if:
condition:
- lambda: return id(wake_word_engine_location).state == "On device";
- switch.is_on: use_listen_light
then:
- light.turn_on:
red: 100%
green: 89%
blue: 71%
brightness: 60%
effect: none
else:
- if:
condition:
- lambda: return id(wake_word_engine_location).state != "On device";
then:
- light.turn_on:
red: 0%
green: 100%
blue: 100%
brightness: 60%
effect: none
else:
- id: start_wake_word
then:
- wait_until:
and:
- media_player.is_idle:
- speaker.is_stopped:
- if:
condition:
then:
- delay: 1s
- script.wait: reset_led
- micro_wake_word.start:
else:
- if:
condition: voice_assistant.is_running
then:
- voice_assistant.start_continuous:
switch:
name: Use listen light
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
on_turn_off:
optimistic: true
restore_mode: ALWAYS_OFF
on_turn_off:
# Turn off the repeat mode and disable the pause between playlist items
- lambda: |-
id(echo_media_player)
->make_call()
.set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_OFF)
.set_announcement(true)
.perform();
id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 0);
# Stop playing the alarm
- media_player.stop:
announcement: true
on_turn_on:
# Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
- lambda: |-
->make_call()
.set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
.perform();
id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
- media_player.speaker.play_on_device_media_file:
media_file: timer_finished_wave_file
announcement: true
- delay: 15min
select:
name: Wake word engine location
optimistic: true
restore_value: true
options:
- In Home Assistant
- On device
initial_option: On device
on_value:
- if:
condition:
lambda: return x == "In Home Assistant";
then:
- delay: 500ms
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
lambda: return x == "On device";
then:
- lambda: id(va).set_use_wake_word(false);
- delay: 500ms
micro_wake_word:
on_wake_word_detected:
- voice_assistant.start:
wake_word: !lambda return wake_word;
vad:
models:
- model: ${micro_wake_word_model}
external_components:
- source: github://esphome/[email protected]
components: [psram]
