Get value out of object dictionary - Sonoff SWV
Hi, so I have Sonoff SWV valve, and it has an atribute which doesn’t separete it’s values, but presents those as:
{‘current_count’: 0, ‘irrigation_capacity’: 0, ‘irrigation_interval’: 0, ‘total_number’: 0}
I would like to get a specific value out of that to show in UI.
I’ve tried “from_json”, tried playing with dictionaries etc etc … but I can’t get any value.
Attributes can be non-string data types, so from_json is likely unnecessary.
{{ state_attr('your_entitiy','your_attribute')['total_number'] }}
Note that templating is rarely supported in dashboard cards, so you will likely need to create a Template sensor to hold the value.
so:
{{state_attr('sensor.garden_drip_hose_valve', 'cyclic_quantitative_irrigation')}}
returns null on it’s own.
{{states('sensor.garden_drip_hose_valve_cyclic_quantitative_irrigation')}}
gives me:
  "current_count": 0,
  "irrigation_capacity": 0,
  "irrigation_interval": 0,
  "total_number": 0
But:
{{states('sensor.garden_drip_hose_valve_cyclic_quantitative_irrigation')['current_count']}}
gives:
'str object' has no attribute 'current_count'
and finally:
{{state_attr('sensor.garden_drip_hose_valve_cyclic_quantitative_irrigation', 'current_count') }}
returns:
null
Also, this is how the value presents it self in device page:
So actual atribute is a json. and I would like to get a value out of this json.
ps. I know what templating in ui entails, and my plan is to get a helper sensor just to get the values out. ATM I’m just trying to get the values in developer tools section just to get going.
The state is a json string… not one of the state attributes. So, you need to use the states() function followed by from_json
{{ (states('sensor.garden_drip_hose_valve_cyclic_quantitative_irrigation')|from_json)['current_count']}}
result:
ValueError: Template error: from_json got invalid input '{'current_count': 0, 'irrigation_capacity': 0, 'irrigation_interval': 0, 'total_number': 0}' when rendering template '{{ (states('sensor.garden_drip_hose_valve_cyclic_quantitative_irrigation')|from_json)['current_count']}}' but no default was specified
And before you think - I’m not picking on you, I’m just pulling my hair because i tried so many things and it doesn’t make sense.
It’s the single quotes… from_json requires double quotes in the json string. I didn’t notice them until you posted the ValueError text.
{% set x = states('sensor.garden_drip_hose_valve_cyclic_quantitative_irrigation').replace('\'','"') %}
{{ (x|from_json)['current_count']}}
Yep, that one does the job, I was actually looking into string replace when you typed the anwser. My one is a bit simpler:
{{ (states('sensor.garden_drip_hose_valve_cyclic_quantitative_irrigation').replace( '\'', '"' )|from_json)['current_count'] }}
