using a Raspberry Pi 4 B and I was able to create the OS using the Raspberry Pi imager.
I used Home Assistant OS 11.2 (RPI 4/400) Released 2023-12-04
it created fine and booted up and I was able to connect to the homeassistant.local:8123 with no issues but now it’s giving this error:
[supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2023.12.0: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2023.12.0/json: Not Found (“No such image: Package raspberrypi4-64-homeassistant · GitHub”)
[supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
I’m new to Home Assistant and somewhat new to the Raspberry Pi can someone please help?
