Getting an Off option Climate operations
I have a bunch of EQ3 MAX! thermostats which Home Assistant is doing a great job handling. In many cases I need to set the temperature on one of them to off (which is 4.5 degrees in Home Assistant), but coming from 23 degrees, it requires a lot of clicks on the small down arrow. I believe I could do an Automation config pr. device, but it would be so much more useful if the option was inside of the Operation combobox. E.g. having an ‘Off’ option that would set the specific device to 4.5 degrees (== Off).
Thanks in advance!
