In my humble opinion (as an owner of a Solis / Pylontech setup) …
Solis are a large, world wide manufacturer with significance market placement. They provide industrial units for large solar farms. “Popular”, and “successful” come to mind.
I believe there is an inverse relationship between the market size/dominance of a manufacturer (any market) and the company openness and support (particularly for the little domestic customer).
[code for - great product, but…]
Do expect a ‘good’ product. Don’t expect easy connection, or easy access. Read access to Modbus is available if you can get around the latest (they change often) protocol / physical connection / register map. This, I believe I am fair saying, is not a plug and play device (whichever model you have).
Your battery looks much like any 48 volt, and will (hopefully) have a dedicated entry in the Solis inverter battery table. That sets all the (highly critical) control values to something appropriate for a 48v Lithium unit. As such, these 48v batteries are ‘universal’. As to ‘hooking up’ to a battery, you don’t. Batteries and inverters have an interesting relationship - the battery BMS looks after the battery, the inverter controls the battery charge / discharge, but actually the battery tells the inverter what to do.
Your battery has CANbus connectivity, and RS485. I would expect the CANbus to be used to connect battery (BMS) to inverter. This is one way with battery shouting at inverter every second with charge limits. Inverter listens and controls the battery voltage to direct charge / discharge. Connecting to this is limited. You can listen in, I do this by listening in on my Pylontech CANbus. It is interesting, but you certainly should not be ‘controlling’ the battery this way. Big NO!
The RS485 is probably a backup inverter control, but may well have a very complex command sequence. Interestingly no RS232 comms, so no ‘console port’, but perhaps the RS485 is a console comms port? Whatever, you probably DO NOT want to be doing anything with the battery anyway. You ‘control’ the battery by ‘controlling’ the inverter (mode / charge limits etc).
Yup. Solis, in my limited experience, change things about every 9 months. I have been using my Solis for 3 years, hence the logging stick has gone through three or four iterations, the protocol two or three, the cloud site a couple, and so on. If you want to stay ahead of the competition build a great product, keep on innovating, and keep changing things.
My suggestion would be, go with a market leading inverter, accept what your installer provides, start experimenting to see if you can connect, build on your successes, setup monitoring first and control later, get it all working as you want. Just don’t expect someone with a Solis inverter older than yours to be of any help, or anyone with a Solis inverter newer than yours to be of any help, because SOLIS KEEP ON CHANGING EVERYTHING about every 9 months.
Yup - great product, but…
