Getting error Configuration is not valid: Integration error: mqqt - Integration 'mqqt' not found
I’m a complete newbie to home assistant… I install HA in a RPI and install and configure Mosquitto.
Now I try to integrate a switch…
In configuration.yaml add:
mqqt: !include mqtt.yaml
And file mqtt.yaml:
switch:
  - name: "output-1"
    unique_id: "output-1"
    state_topic: "server/XXXXXXXX/state"
    command_topic: "server/XXXXXXXX/set"
    payload_on: '{"relay1":{"on":1}}'
    payload_off: '{"relay1":{"on":0}}'
    value_template: "{{ value_json.relay1.on }}"
    state_on: 1
    state_off: 0
Always getting this error:
Getting error Configuration is not valid: Integration error: mqqt - Integration ‘mqqt’ not found
Can someone help please?
thanks in advance
It’s mqtt
What exactly did you do ?
There are 2 things to do on HA OS:
  • install and configure the Mosquitto add-on
  • add the MQTT integration to HA
My instinct tells me you only did the first part.
