Getting Lots of errors
I am running an Odroid N2+. I am trying to go more voice vs dashboard. When ever I use VOIP or ASSISTANT I get these errors. But sometime it still goes though. But very very later on. Are there any suggestions? I completely removed Whisper and reinstalled. Same thing every time. I am using it same machine and from the addons.
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name='wyoming event handler' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=ConnectionResetError('Connection lost')>
  File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 41, in run
    if not (await self.handle_event(event)):
  File "/usr/local/lib/python3.11/dist-packages/wyoming_faster_whisper/faster_whisper_handler.py", line 96, in handle_event
    await self.write_event(self.wyoming_info_event)
  File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 29, in write_event
    await async_write_event(event, self.writer)
  File "/usr/local/lib/python3.11/dist-packages/wyoming/event.py", line 136, in async_write_event
    await writer.drain()
  File "/usr/lib/python3.11/asyncio/streams.py", line 378, in drain
    await self._protocol._drain_helper()
  File "/usr/lib/python3.11/asyncio/streams.py", line 167, in _drain_helper
    raise ConnectionResetError('Connection lost')
ConnectionResetError: Connection lost
INFO:faster_whisper:Processing audio with duration 00:02.020
INFO:wyoming_faster_whisper.faster_whisper_handler: 50,000
INFO:faster_whisper:Processing audio with duration 00:02.360
INFO:wyoming_faster_whisper.faster_whisper_handler: Good morning.
