Has anyone have this working with ESPHome builder / Home Assistant?
I have
- M5Stack ATOM Lite
- M5Stack EnvIII sensor (connected with HY2.0-4P Cable).
- ESPHome builder 2025.6.3
- HA Green running 2025.7 (also tested on 2025.6.x)
I can compile and install the config to the atom lite over USB connected to the HA Green. Once installed I can access the ATOM Lite via wifi
At the end of the install process I do get this error, with similar error if I access the logs over wifi
[11:47:31][C][i2c.idf:083]: I2C Bus:
[11:47:31][C][i2c.idf:084]: SDA Pin: GPIO21
[11:47:31][C][i2c.idf:084]: SCL Pin: GPIO22
[11:47:31][C][i2c.idf:084]: Frequency: 50000 Hz
[11:47:31][C][i2c.idf:094]: Recovery: bus successfully recovered
[11:47:31][I][i2c.idf:104]: Results from bus scan:
[11:47:31][I][i2c.idf:106]: Found no devices
[11:47:31][C][factory_reset.button:011]: Factory Reset Button 'Factory reset'
[11:47:31][C][factory_reset.button:011]: Icon: 'mdi:restart-alert'
[11:47:31][C][sht3xd:049]: SHT3xD:
[11:47:31][D][sht3xd:052]: Error reading serial number
[11:47:31][E][sht3xd:061]: Communication with SHT3xD failed!
[11:47:31][E][component:088]: Component sht3xd.sensor is marked FAILED:
Would anyone see where I have gone wrong, I am assuming that the code snippet for the env sensor needs tweaking but I am unsure how to get the correct settings.
Yaml
esphome:
friendly_name: air-test
min_version: 2025.6.0
name_add_mac_suffix: true
# https://github.com/esphome/issues/issues/5294#issuecomment-2075784260
# https://github.com/esphome/issues/issues/5710#issuecomment-2063260398
#external_components:
# - source:
# type: git
# url: https://github.com/mrtoy-me/esphome-my-components
# ref: main
# components: [ sht3xd ]
esp32:
board: m5stack-atom
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa="
ota:
- platform: esphome
password: "aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 10.1.1.5
gateway: 10.1.1.1
subnet: 255.255.255.0
button:
- platform: safe_mode
name: Safe Mode Boot
- platform: factory_reset
# Example configuration entry for the ENV III sensor
i2c:
sda: 21
scl: 22
scan: True
# Individual sensors
- platform: sht3xd
temperature:
humidity:
address: 0x44
update_interval: 60s
