I’m trying to get the hang of MQTT but whatever information I come across always seems to be missing something so I’m hoping you guys can enlighten me.
What am I doing wrong? I think I’d prefer to run an MQTT broker locally (I have mosquitto running alongside one of my Home Assistant instances), but I can’t seem to configure it ie. setting up of username/password/port.
Any help would be appreciated.
Edit: When viewing the CloudMQTT logs, I can see:
2019-05-30 10:56:07: Saving in-memory database to /var/lib/mosquitto/12829/db
So if I’m seeing it right, the script I have running is publishing results to MQTT, but I can’t seem to get at them.
Hi, thanks for the tip. I’ve connected a client to the MQTT service, but I’m not seeing any messages, which leads me to believe they’re not being published.
because I suppose this is where it’s going wrong. It’s odd though, because I set the update interval to 30 minutes and I’m getting a log entry every 30 minutes to confirm data being written.
I’ve actually got a stocks tracker working, but then it runs directly in Home Assistant, which is a bit flakey.
I sortof thought I’d make the foray into MQTT because I need to understand it sooner or later for more complicated tasks.
I’ve found enough to give me a very broad understanding of MQTT and what it can do, but the finer details seem to be either missing or not explained properly. Can you perhaps point me in the direction of useful guides for understanding MQTT better and setting it up?
