The Tutorial - https://youtu.be/34TkFKlVV3A
I will be showing you the way to setup Themes in Home Assistant
Before we start, I would like to thank JuanMTech for making these 20 themes!!
JuanMTech-https://www.youtube.com/channel/UCR7Xa7cU9wfkSY9v3yN2Vtw
Let’s Start
For this you will have to activate, the windows feature:
SMB 1.0/CIFS File Sharing Support
To activate this, follow these steps:
- Click the Start button.
- Click Control Panel.
- Click Programs.
- Click Turn Windows features on or off.
- Scroll down to find “SMB 1.0/CIFS File Sharing Support”.
- Enable it by clicking on the box beside (left) the name of the feature.
- Then clik OK and restart the pc…
Now make sure your HassOS is running,
STEPS:
Download the Samba Share add-on from the Official add-ons list that is located in the supervisor tab and in
‘Add-On Store’. I have already downloaded so I am not installing it again… -
Now install the add-on and start it up (if you cant then go ahead with the steps…),
Now click on the configuration tab and add a password of your choice /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
or
if you do not want to add a password then don’t leave the space empty, add 2 single quotes " ‘’ " instead of null and save the configuration… at the prompt:
Samba share
Do you want to restart the add-on with your changes?
If the prompt doesnt appear don’t worry save… and go to the info tab and click on start…
Click on “Restart Add-On” -
Now Open ‘File Explorer’ and go to Networks… You Will find a folder named HOMEASSISTANT, Open that,
you will find all the Home Assistant Files there… -
Download the “Themes File”(End of Description) from the description, And copy it into the HOMEASSISTANT- Config Folder, Now
open the configuration.yaml file using notepad… And Add :
frontend:
themes: !include themes.yaml
NOTE!!!
Make sure that there are only 2 spaces from the right end of the page for “themes: !include themes.yaml” and no spaces between “frontend:” and the right end of the page
SAVE the file and restart Home Assistant now that we have restarted now open the site
And now open your profile … And under themes choose the theme of your choice!!
Voila 20 themes and thanks to JuanMTech!!!
LIKE, SHARE AND SUBSCRIBE!!!
The Themes file-
https://mega.nz/file/6WBUEIIb#yiqaAEfzm1egpo-stZmGtux6rzQB_czlX1x3yFYCj3Y
Contact Me-
My Discord Server- 95EXaD5
My Discord ID- THUGGAMER#4742
