Flashed the Sonoff TH16 with Tasmota. Can access it directly and get the temp measurement, as well as turning it on/off. The sonoff is coupled with a DS18B20 temp sensor.
Configured a sensor in Config.yaml file. I can get the entity shown but with an “unknown” temp.
The mqtt toipc I configured in the sonoff menu is : sonoff_th16.
How can I increase the temp update frequency on the dashboard? I noticed that there is a lag between the temp updated on the tasmota gui and the temp on the device?
The data appears on the dashboard when the tasmota’ed device sends it via MQTT. By default this is every 300 secs, but this can be changed on the device using the teleperiod command
