Getting the latest released HA docker image version
I’ve recently been trying to make my upgrade process more efficient; in doing so I’d like to check as part of my automation what is the latest released docker image in docker hub, I’ve managed to get it in a JSON form :
https://registry.hub.docker.com/v1/repositories/homeassistant/home-assistant/tags
Which gives me a ready-to-work-on JSON. How do I store the latest released build (in my case 0.80.3) in an HA sensor (probably through the RestFul sensor component) ?
Thanks in advance
command line sensor
curl -s https://registry.hub.docker.com/v1/repositories/homeassistant/home-assistant/tags | jq '.[].name' | sort -r | sed "4q;d" | sed -e 's/^"//' -e 's/"$//'
Check out this custom component:
How would that help me in getting the latest docker image version ?
Thanks, need to figure out now how to integrate it in the HASS docker container
I ended up using a rest sensor since running on docker I don’t have JQ installed :slight_smile:
- platform: rest
  name: Home Assistant Docker Latest Image Build
  scan_interval: 300
  resource: https://registry.hub.docker.com/v1/repositories/homeassistant/home-assistant/tags
  headers:
    Content-Type: application/json
    User-Agent: Home Assistant REST sensor
  value_template: >-
        {% for image_build in value_json | reverse if image_build.name.split(".")[0]=="0"  %}
          {% if loop.first %}
               {{image_build.name}}
          {% endif %}
        {% endfor %}
Just to follow up on this… I tweaked this to omit any builds that contain the letter “b”. So currently this should only include stable releases.
- platform: rest
  scan_interval: 300
  headers:
  value_template: >-
    {%- for image_build in value_json | reverse if image_build.name.split(".")[0]=="0" and "b" not in image_build.name.split(".")[2] -%}
      {%- if loop.first -%}
        {{ image_build.name }}
      {%- endif -%}
    {% endfor %}
Thanks for that,
I’m still using the one with the beta builds to track the progress of builds on docker hub, but your approach has benefits as well of course
