my z2m is not finding devices no matter what i do.
sonoff dongle -e - with latest 8 version firmware, core mqtt broker. no success. not finding either the router (itead dongle 3.0 with router firmware) or any of the sonoff devices.
below is configuration
version: 4
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: xxxx
password: xxxx
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230221110716-if00
adapter: ember
baudrate: 115200
rtscts: false
advanced:
log_level: debug
channel: 15
network_key:
- 68
- 125
- 169
- 255
- 96
- 15
- 177
- 45
- 201
- 20
- 7
- 39
- 209
- 222
- 69
- 249
pan_id: 42165
ext_pan_id:
- 126
- 168
- 4
- 158
- 9
- 30
- 69
- 142
transmit_power: 20
frontend:
enabled: true
port: 8099
homeassistant:
enabled: true
devices:
'0x847127fffec9a46f':
friendly_name: '0x847127fffec9a46f'
z2m logs - last few lines
oin_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}'
[2025-05-07 22:09:07] debug: z2m: Discovering entities to Home Assistant
[2025-05-07 22:09:07] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0xdc8e95fffe00a26f/connection_state/config', payload '{"device":{"hw_version":"EmberZNet 8.0.2 [GA]","identifiers":["zigbee2mqtt_bridge_0xdc8e95fffe00a26f"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.3.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"2.3.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0xdc8e95fffe00a26f_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'binary_sensor/1221051039810110150109113116116_0xdc8e95fffe00a26f/restart_required/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'button/1221051039810110150109113116116_0xdc8e95fffe00a26f/restart/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'select/1221051039810110150109113116116_0xdc8e95fffe00a26f/log_level/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'sensor/1221051039810110150109113116116_0xdc8e95fffe00a26f/version/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'sensor/1221051039810110150109113116116_0xdc8e95fffe00a26f/coordinator_version/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'sensor/1221051039810110150109113116116_0xdc8e95fffe00a26f/network_map/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'switch/1221051039810110150109113116116_0xdc8e95fffe00a26f/permit_join/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'sensor/0x847127fffec9a46f/light_indicator_level/config', already discovered
[2025-05-07 22:09:07] debug: z2m: Skipping discovery of 'sensor/0x847127fffec9a46f/linkquality/config', already discovered
[2025-05-07 22:14:00] debug: z2m: Saving state to file /config/zigbee2mqtt/state.json
[2025-05-07 22:19:00] debug: z2m: Saving state to file /config/zigbee2mqtt/state.json
[2025-05-07 22:24:00] debug: z2m: Saving state to file /config/zigbee2mqtt/state.json
