Gig Guide - Ticketmaster/Fatsoma/Skiddle
I’ve created yet another most likely niche integration, but I thought I’d share it. Some of the code was corrected by Big Pickle for full transparency.
Basically I wanted a way to view upcoming gigs along with a means of buying tickets easily. This is v0.1.1 of the end result. I have a few plans for it, including aligning/filtering with Spotify favourites/bands in playlists.
I hope someone finds it of use, it’s submitted to HACS but still pending, so manual install for now if you want to test it.
All details are here :GitHub - Thrasher2020/home-assistant-gigfinder: Gig Finder — a Home Assistant integration that watches live music listings from Ticketmaster, Fatsoma and Skiddle near your home, merging them into sensors and a calendar. · GitHub
Your link is broken.
Fixed :slight_smile:
Thanks for pointing it out!
No worries, thanks for the TM calendar.
I’ve added a companion integration for this - it uses your Discogs collection and optionally (using the SpotifyPlus integration) Spotify playlists to filter the results, so you only see the bands you like!
