Github emoji
Whenever there is any HACS integration update, the author usually uses github emoji in the change description. Is there any way to install those into home assistant, so it then appears as icon instead of text?
I don’t know if it will work, but there’s the Material Symbols integration in HACS:
That unfortunately isn’t it. The referenced ones are “m3o:iconname”, while github emojis are “:iconname:”
