I’ve installed glances, and can correctly see it via http://192.168.1.53:61208
My config looks like this:
- platform: glances
host: 192.168.1.53
resources:
- 'disk_use_percent'
- 'disk_use'
- 'disk_free'
- 'memory_use_percent'
- ... SNIP
When I restart HASS I don’t get any errors but none of the glance servers get added either.
My entire config can be seen here if it helps: https://github.com/rossdargan/hass-config/blob/master/configuration.yaml#L79
fabaff
(Fabian Affolter)
May 26, 2017, 8:54am
2
Is your used version of glances greater than 2.3?
yeah, I just installed it.
fabaff
(Fabian Affolter)
May 26, 2017, 8:55am
4
And what release are you using?
2.9.1 (sorry took a while to figure out how to find the version!)
fabaff
(Fabian Affolter)
May 26, 2017, 9:22am
6
Works fine for me on dev
with Glances v2.5.1 with psutil v4.3.0
Does my config look correct? It’s odd as I’m not seeing any errors in the log.
fabaff
(Fabian Affolter)
May 26, 2017, 10:41am
8
Can you try to retrieve a value with the command line, please?
$ curl -X GET http://192.168.1.53:61208/api/2/mem/free
The glances
sensor is basically just doing this. But as the access to the website works your server side seems to work.
hmm. That just doesn’t do anything - it gives me that ability to type stuff in and press enter but I never get a response. In the end I have to ctrl-c out.
Hmm!
rpitera
(Robert Pitera)
May 26, 2017, 1:34pm
10
That is kind of weird as I just performed the same test and got a response:
pi@raspi1:~$ curl -X GET http://192.168.1.181:61208/api/2/mem/free
{"free": 574656512}pi@raspi1:~$
Glances 2.6.2, HA 0.45.0
The only difference between my config in HA and yours is that I specified the port.
- platform: glances
host: 192.168.1.181
port: 61208
resources:
- 'disk_use'
- 'disk_free'
- 'memory_use'
- 'memory_free'
- 'swap_use_percent'
- 'swap_use'
- 'swap_free'
- 'processor_load'
- 'process_running'
- 'process_total'
- 'process_thread'
- 'process_sleeping'
But you should get a response from the command line @fabaff gave like I did. You may want to check again to make sure it is running, maybe it went down since the last test in your browser.
rpitera
(Robert Pitera)
May 26, 2017, 1:44pm
11
Just to check, I updated both psutil and glances to the latest versions, restarted the service and checked again and I am still working.
So a reboot started the api working, but it still isn’t working in hass.
The curl command returns
{"free": 3280195584}
I’ve reduced my config to this:
- platform: glances
host: 192.168.1.53
port: 61208
resources:
- 'memory_free'
but I still don’t see glances in states.
rpitera
(Robert Pitera)
May 27, 2017, 4:11pm
13
Are you sure you’re looking in the right place? Should be under sensor.docker4.ram_free
rpitera
(Robert Pitera)
May 27, 2017, 4:16pm
15
Yeah, weird that it’s not the same naming convention. I can see how that would throw you off.
cewjr9842
(Chuck W.)
September 8, 2017, 1:12am
16
I am having inssues installing glances in Hassio for some reason? I want to remotely monitor a Desktop PC on my network.
Can anyone point a a noob in the right direction? I was tryingto follow the sisntall steps here , but I am not sure if i am doing something right. I can not install it on my PI.
grantc
(Grant)
July 2, 2019, 7:16am
17
Not sure what is going on here - can start with glances -w and
use the web interface on http://0.0.0.0:61208/
but when I try "http://IP:61208/api/2 or 3 I get file does not exist.
curl -X GET http://192.168.1.2:61208/api/2/mem/ confirms this also
<html>
<head>
<title>Error: 404 Not Found</title>
<style type="text/css">
html {background-color: #eee; font-family: sans;}
body {background-color: #fff; border: 1px solid #ddd;
padding: 15px; margin: 15px;}
pre {background-color: #eee; border: 1px solid #ddd; padding: 5px;}
</style>
</head>
<body>
<h1>Error: 404 Not Found</h1>
<p>Sorry, the requested URL <tt>'http://192.168.1.2:61208/api/2/mem/free'</tt>
caused an error:</p>
<pre>File does not exist.</pre>
</body>
</html>
Ubuntu 19.04, running HA in VE
grantc
(Grant)
July 2, 2019, 8:15am
18
Sorted- using version 3 requires a version entry in the config.yaml… defaults to 2 otherwise.
Petrica
(PetricaM)
July 2, 2019, 8:24am
19
You can also use the following options (however, some might not be applicable): alert, amps, batpercent, cloud, core, cpu, diskio, docker, folders, fs, gpu, help, ip, irq, load, mem, memswap, network, now, percpu, ports, processcount, processlist, psutilversion, quicklook, raid, sensors, smart, system, uptime, wifi
