Glances sensor missing
Glances doesn’t want to make any sensor in HA.
In configuration i have
  - platform: glances
    host: 192.168.7.254
    version: 3
    port: 61208
    resources:
      - "memory_use"
      - "disk_use_percent"
      - "cpu_use_percent"
logger:
  default: info
  logs:
    homeassistant.components.glances: debug
From cmd works correctly
bash-5.0# curl -X GET http://192.168.7.254:61208/api/3/mem/free
{“free”: 1724407808}
Log looks ok
bash-5.0# grep glances home-assistant.log
2019-11-30 18:41:45 INFO (SyncWorker_19) [homeassistant.loader] Loaded glances from homeassistant.components.glances
2019-11-30 18:41:54 INFO (MainThread) [homeassistant.setup] Setting up glances
2019-11-30 18:41:54 INFO (MainThread) [homeassistant.setup] Setup of domain glances took 0.0 seconds.
2019-11-30 18:41:54 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.glances
bash-5.0#
bash-5.0# grep memory_use home-assistant.log
bash-5.0#
Where should I look for a problem?
show us your lovelace code
Here is my all lovelace file: https://anotepad.com/note/read/tcak695
paste in here
    "data": {
        "config": {
            "resources": [
                    "type": "module",
                    "url": "/customcards/github/custom-cards/tracker-card.js?track=true"
                    "type": "js",
                    "url": "/local/custom-lovelace/monster-card/monster-card.js"
                    "type": "js",
                    "url": "/local/custom-lovelace/home-setter/home-setter.js"
                    "type": "js",
                    "type": "module",
                    "url": "/local/custom-lovelace/weather-card/weather-card.js"
                    "type": "module",
                    "url": "https://cdn.jsdelivr.net/gh/bramkragten/custom-ui@master/weather-card/weather-card.min.js"
            "title": "HA",
            "views": [
                    "badges": [],
                    "cards": [
                            "entities": [
                                "sensor.zewnetrz",
                            "show_header_toggle": false,
                            "title": "Temperatura",
                            "type": "entities"
                            "entities": [
                                "switch.tio1_vout1",
                                "light.tio1_vout2"
                            "title": "Ledy",
                            "type": "entities"
                            "entities": [
                                    "entity": "sensor.last_boot_template"
                                    "entity": "sensor.processor_use"
                                    "entity": "sensor.memory_use_percent"
                                    "entity": "sensor.disk_use_percent"
                                    "entity": "sensor.disk_use_percent_mnt_ssd"
                                    "entity": "sensor.disk_use_percent_mnt_hdd"
                            "title": "System",
                            "type": "entities"
                            "entities": [
                                "sensor.speedtest_ping",
                                "sensor.speedtest_download",
                                "sensor.speedtest_upload"
                            "title": "Speedtest",
                            "type": "entities"
                            "entities": [
                                "input_number.esp_lazienka_czas",
                            "title": "Wentylatory",
                            "type": "entities"
                            "entities": [
                                "sensor.lazienka_t",
                            "title": "\u0141azienki",
                            "type": "entities"
                            "entities": [
                                "binary_sensor.nas",
                            "title": "Net",
                            "type": "entities"
                            "entities": [
                            "title": "Satel",
                            "type": "entities"
                            "entities": [
                                    "entity": "switch.skrypt"
                                    "entity": "switch.lazienka_gora_podloga"
                            "title": "Prze\u0142\u0105cznik",
                            "type": "entities"
                    "path": "default_view",
                    "title": "HA"
                    "badges": [],
                    "cards": [
                            "entities": [
                                "light.tio1_vout2"
                            "title": "Ledy",
                            "type": "entities"
                    "icon": "mdi:lightbulb",
                    "path": "led",
                    "title": "Led"
                    "badges": [],
                    "cards": [
                            "entities": [
                            "type": "entities"
                            "entities": [
                                "sensor.speedtest_upload",
                            "type": "history-graph"
                            "cards": [
                                    "entities": [
                                    "type": "entities"
                                    "entities": [
                            "type": "vertical-stack"
                            "entities": [
                            "title": "System",
                            "type": "entities"
                    "icon": "mdi:server",
                    "path": "server",
                    "title": "Server"
                    "badges": [],
                    "cards": [
                            "entities": [
                                    "entity": "sensor.licznik_gazu"
                                    "entity": "switch.piec"
                                    "entity": "input_number.piec"
                            "title": "Piec",
                            "type": "entities"
                            "entities": [
                                "switch.step2",
                            "title": "Rozdzielacze",
                            "type": "entities"
                            "entities": [
                                    "entity": "input_number.temp_png"
                                    "entity": "input_number.temp_lazienka"
                                    "entity": "input_number.temp_lazienka_rano"
                            "title": "AU Piec",
                            "type": "entities"
                    "icon": "mdi:stove",
                    "path": "piec",
                    "title": "Piec"
                    "badges": [],
                    "cards": [
                            "entities": [
                                    "name": "Piec",
                                    "type": "weblink",
                                    "url": "http://yogi:3000/dashboard/db/piec?orgId=1"
                            "title": "Wykresy",
                            "type": "entities"
                    "icon": "mdi:chart-areaspline",
                    "path": "wykres",
                    "title": "Wykres"
                    "badges": [],
                    "cards": [
                            "entities": [
                                    "entity": "automation.piec_png"
                                    "entity": "automation.piec_wlaczanie_rano"
                                    "entity": "automation.piec_lazienka_w_dzien"
                                    "entity": "automation.piec_lazienka_w_nocy"
                                    "entity": "automation.piec_slider"
                                    "entity": "automation.piec_reset_slider_to_0"
                                    "entity": "automation.piec_15"
                                    "entity": "automation.piec_lazienka"
                            "title": "AU Piec",
                            "type": "entities"
                            "entities": [
                                    "entity": "automation.cyrkulacja_20_00"
                                    "entity": "automation.cyrkulacja_6_00_pn_pt"
                                    "entity": "automation.cyrkulacja_7_00_8_00_30_sb_nd"
                                    "entity": "automation.cyrkulacja_alarm_off"
                            "title": "AU Cyrkulacja",
                            "type": "entities"
                            "entities": [
                                    "entity": "automation.wentylator_lazienka_09_30"
                                    "entity": "automation.wentylator_lazienka_gora_09_30"
                                    "entity": "automation.wentylator_piwnica_09_30"
                                    "entity": "automation.wentylator_lazienka_00_30"
                                    "entity": "automation.wentylator_lazienka_gora_00_30"
                                    "entity": "automation.wentylator_piwnica_00_30"
                                    "entity": "automation.wentylator_wc"
                            "title": "AU Wentylator",
                            "type": "entities"
                            "entities": [
                                    "entity": "automation.satel_alarm"
                            "title": "AU Satel",
                            "type": "entities"
                    "path": "au",
                    "title": "AU"
                    "badges": [],
                    "cards": [
                            "cards": [
                                    "entities": [
                                            "entity": "sensor.airly_quality"
                                            "entity": "sensor.airly_level"
                                            "entity": "sensor.airly_description"
                                            "entity": "sensor.airly_temperature"
                                            "entity": "sensor.airly_humidity"
                                            "entity": "sensor.airly_pressure"
                                            "entity": "sensor.airly_pm1"
                                            "entity": "sensor.airly_pm25"
                                            "entity": "sensor.airly_pm10"
                                    "title": "Airly",
                                    "type": "entities"
                            "entity": "weather.dark_sky",
                            "name": " ",
                            "type": "custom:weather-card"
                    "icon": "mdi:cloud",
                    "panel": false,
                    "title": "Pogoda"
                    "badges": [],
                    "cards": [
                            "entities": [
                                    "entity": "input_number.bajki_timeout"
                            "title": "cmd",
                            "type": "entities"
                    "icon": "mdi:rocket"
                    "badges": [],
                    "cards": [
                            "content": "Welcome to your **Lovelace UI**.  \n",
                            "title": "Lovelace",
                            "type": "markdown"
                            "cards": [
                                    "entity": "sensor.disk_use_percent",
                                    "max": 100,
                                    "min": 0,
                                    "name": "/",
                                    "severity": {
                                        "green": 30,
                                        "red": 80,
                                        "yellow": 60
                                    "theme": "default",
                                    "type": "gauge",
                                    "unit": "%"
                                    "entity": "sensor.disk_use_percent_mnt_ssd",
                                    "max": 100,
                                    "min": 0,
                                    "name": "SSD",
                                    "severity": {
                                        "green": 0,
                                        "red": 0,
                                        "yellow": 0
                                    "theme": "default",
                                    "type": "gauge",
                                    "unit": "%"
                                    "entity": "sensor.disk_use_percent_mnt_hdd",
                                    "max": 100,
                                    "min": 0,
                                    "name": "HDD",
                                    "severity": {
                                        "green": 0,
                                        "red": 0,
                                        "yellow": 0
                                    "theme": "default",
                                    "type": "gauge",
                                    "unit": "%"
                            "type": "horizontal-stack"
                            "entities": [
                                "sensor.zewnetrz",
                                "sensor.sypialnia",
                                "sensor.PNG",
                                "sensor.piec_CO_zasilanie"
                            "title": "history-graph",
                            "entity": "light.tio1_vout3",
                            "type": "light"
                            "detail": 0,
                            "entity": "sensor.png",
                            "graph": "line",
                            "hours_to_show": 24,
                            "name": "PNG",
                            "type": "sensor"
                            "entity": "sensor.sypialnia",
                            "max": 100,
                            "min": 0,
                            "severity": {
                                "green": 0,
                                "red": 0,
                                "yellow": 0
                            "theme": "default",
                            "type": "gauge"
                            "aspect_ratio": "50%",
                            "type": "iframe",
                            "url": "http://www.mojapogoda.com/pogoda-na-swiecie/pogoda-lokalna/miasto/48X32/krakow.html"
                            "aspect_ratio": "70%",
                            "title": "Meteo",
                            "type": "iframe",
                            "url": "https://meteo.org.pl/img/um/krakow.png"
                            "pages": [
                                    "name": "Main",
                                    "path": "lovelace/0"
                                    "name": "Mobile",
                                    "path": "lovelace/mobile"
                            "type": "custom:home-setter"
                            "detail": 0,
                            "entity": "sensor.wedzarka",
                            "graph": "line",
                            "hours_to_show": 4,
                            "name": "W\u0119dzarka",
                            "type": "sensor"
                            "entities": [
                                    "entity": "input_number.opwm1"
                                    "entity": "switch.tio1_out1"
                            "title": "Test",
                            "type": "entities"
                            "entities": [
                                "updater.updater"
                            "show_header_toggle": true,
                            "title": "Update",
                            "type": "entities"
                            "entities": [
                                    "name": "Netdata",
                                    "type": "weblink",
                                    "url": "http://yogi:19999/"
                            "title": "Link",
                            "type": "entities"
                    "panel": false,
                    "path": "",
                    "title": "exx"
                    "badges": [],
                    "cards": [
                            "card": {
                                "title": "Update",
                                "type": "entities"
                            "filter": {
                                "include": [
                                        "domain": "updater"
                                        "entity_id": "sensor.current_version"
                                        "entity_id": "updater.updater"
                            "type": "custom:monster-card"
                            "type": "custom:tracker-card"
                    "title": "ADM"
                    "badges": [],
                    "cards": [],
                    "icon": "mdi:toggle-switch-off-outline",
                    "title": "switch"
    "key": "lovelace",
    "version": 1
Check in your developer tools - states page.
My glances sensors show up as sensor.glances_disk_used_percent
So most likely change
to sensor.glances.disk_use_percent.
But to be sure have a look in the Check in your developer tools - states page. for the correct sensor name.
In developer tools - states I don’t have any glance sensor. Ctrl+F with glance has 0 results
OK so do you have sensor.disk_use_percent?
or is it disk_used_percent?
In fairness I am using glances as an addon. This with protection mode disable allows me to get information from the host machine.
Are you trying to connect to a remote node?
I have sensor.disk_use_percent, but it come from systemmonitor, if I turn this platform off, it doesn’t appear in the list of sensors
- platform: systemmonitor
  resources:
    - type: disk_use_percent
      arg: /
      arg: /mnt/ssd/
Yes, it is remote server, I can sucesfully get data with curl.
Is it possible to debug glance platform ? I enabled debug, but I don’t see any logs.
OK just went back up and looked at your original post.
You have the name option set.
So would you check if sensor.Server.disk_use_percent exits please?
I don’t have any sensor.Server.*
Is it bug in glances platform ?
Thanks. now as I don’t use the component then I will have to test it.
Unless anyone else can chime in are you OK to wait and I will set up a similar setup to yourself.
That should help to pinpoint your specific issue. Just a user trying to help is all!
Does your glances show up in your integrations?
Have you tried removing the entry from your configuration yaml and adding it through integrations?
Could you explain how to add it through integrations?
Remove it from your config.yaml
Go to the COG and under server controls do a config check and a restart. Then go to the COG and choose integrations. Then click the plus sign and follow the prompts.
With integrations work correctly. Thak all :smile:
I see 19 items sensor.glances.*
Whether it is possible to display sensor.glances_disk_used_percent for diferent disks eg. for /mnt/sdd i /mnt/hdd ?
