Glances stop working with update 21.1
Hi , Just updated Glances to 21.1 and its stopped working. It starts but after a short time stops. If I try to access it I now get bad gateway and going back to it then shows it as stopped.
My Glances config is shown n but hasn’t changes
Any ideas … is it just me or anyione else had the same problem.
Many thanks
Andy
Try posting the log too, mine is working fine btw, updated yesterday.
This is the log I get from Glances when starting . Cant see anything wrong. But I have noticed that when I start Glances it stops NGINX and the same the other way .
Could somebody screen shot the correct config for both please so I can check mine
Many thanks
Andy
Yeah, that’s beyond my range of skills :slight_smile:
 Add-on: Glances
 A cross-platform system monitoring tool
 Add-on version: 0.21.1
 You are running the latest version of this add-on.
 System: Home Assistant OS 12.1  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2024.3.3
 Home Assistant Supervisor: 2024.03.0
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
INFO: Starting Glances...
2024-03-26 01:02:30,720 -- INFO -- Start Glances 3.4.0.5
2024-03-26 01:02:30,721 -- INFO -- CPython 3.11.8 (/usr/bin/python3) and psutil 5.9.8 detected
2024-03-26 01:02:30,736 -- INFO -- Read configuration file '/etc/glances.conf'
2024-03-26 01:02:30,775 -- INFO -- Start GlancesWebServer mode
2024-03-26 01:02:31,027 -- WARNING -- Sparklines module not found (No module named 'sparklines')
2024-03-26 01:02:31,031 -- WARNING -- Missing Python Lib (No module named 'py3nvml'), Nvidia GPU plugin is disabled
2024-03-26 01:02:31,178 -- WARNING -- Error loading Podman deps Lib. Podman feature in the Containers plugin is disabled (No module named 'podman')
2024-03-26 01:02:31,236 -- WARNING -- Missing Python Lib (No module named 'wifi'), Wifi plugin is disabled
2024-03-26 01:02:31,236 -- WARNING -- Wifi lib is not compliant with Python 3, Wifi plugin is disabled
2024-03-26 01:02:31,262 -- WARNING -- Missing Python Lib (No module named 'pySMART'), HDD Smart plugin is disabled
2024-03-26 01:02:31,290 -- WARNING -- Missing Python Lib (No module named 'pymdstat'), Raid plugin is disabled
2024-03-26 01:02:33,426 -- INFO -- Glances RESTful API Server started on http://127.0.0.1:61209/api/3/
2024-03-26 01:02:33,435 -- INFO -- Glances Web User Interface started on http://127.0.0.1:61209/
INFO: Starting NGinx...
Yeh me too … Help … anyone got an idea why this is happening
Dont ask me why but after a few stop and restarts Glances is now working … I have no idea what happened or why it stopped after the update for a day ot two … but all fixed …
