Hi, i’m slowly getting the hang of things - building my first custom sensor templates + dashboard. Enjoying learning and getting closer to what I want. This is about the Electricity flow to and from my house.
There are 6 values I want available for my dashboard. Three that come directly from the sma solar panel integration, (renamed because I find their naming confusing): grid2home, home2grid, solarproduction, and 3 that are calculated: homeconsumption Overproduction and el_flow
the three calculated values all use the same intermediate calculation, which I would normally want to do with global variables
Do I…
- create 3 sensors, each repeating a large chunk of code from the others?
- create ‘intermediate sensors’ that calculate intermediate values, and call these sensor values instead of repeating code?
- create 1 sensor with 5 attributes (would that help me in not repeating the chunks of code?)
Here’s what I have now, as you can se
el_flow:
friendly_name: Electricity Net Outward Flow
unit_of_measurement: "W"
value_template: >-
{% set solarproduction = states('sensor.sb5_0_1av_41_706_pv_power')|int %}
{% set grid2home = states('sensor.sb5_0_1av_41_706_metering_power_absorbed')|int %}
{% set home2grid = states('sensor.sb5_0_1av_41_706_metering_power_supplied')|int %}
{% if grid2home > 0 %} #UnderProduction
{% set Overproduction = 0 %}
{% set ElFlow = 0 - grid2home %}
{% set HomeConsumption = 0 - solarproduction- grid2home %}
{% else %} #OverProduction
{% set Overproduction = 1 %}
{% set HomeConsumption = solarproduction - home2grid %}
{% set ElFlow = home2grid %}
{% endif %}
{{ElFlow}}
