Go E Charger
Dear All,
I have installed the MQTT Server and connected the Go E Wallbox. Everything is working and I see all the entities.
I want to edit the current ampere loading speed. I can only change “Set Max Ampere Limit”, but this will not change the actual ampere the car is loading with.
I can’t find any other entity to change the actual loading speed.
Can you help me? Do I need a special new entity or how can I fix this?
Best Regards
Robert
