I’m trying to get PV surplus charging working with my go-e Gemini charger.
I’ve installed the ha-goecharger-api2 integration in Home Assistant and enabled APIv2. The charger is reachable locally and responds to /api/status.
Here’s what I get from:
http://[IP]/api/status?filter=lmo,fup,acp,pgrid,ppv
"lmo": 4,
"fup": true,
"acp": true,
"pgrid": -7.22,
"ppv": 7250.47
That should be correct:
- Logic mode (lmo) is set to Eco (Awattar)
- PV surplus mode (fup) is enabled
- Charge pausing (acp) is enabled
- pgrid is negative → I’m feeding ~7.2 kW into the grid
- The charger works perfectly in normal (non-surplus) mode
However, it doesn’t start charging automatically in surplus mode.
I’m sending data to the wallbox every 5 seconds using this Home Assistant automation:
alias: PV surplus charging
triggers:
- seconds: /5
trigger: time_pattern
conditions:
- condition: and
conditions:
- condition: sun
after: sunrise
- condition: sun
before: sunset
- condition: not
conditions:
- condition: state
entity_id: sensor.goe_266304_car_value
state: Inaktiv/Frei
actions:
- data:
pgrid: "{{ states('sensor.shellypro3em_08f9e0e95ddc_total_active_power')}}"
ppv: "{{ states('sensor.shellypro3em_08f9e0e95ddc_total_apparent_power')}}"
action: goecharger_api2.set_pv_data
mode: single
I see that pgrid and ppv arrive at the wallbox via the /api/status endpoint, but still no charging starts.
Is there something I’m missing?
Thanks a lot in advance!
