Golmar / Quvii Local — open your Golmar G2Call+ door stations from Home Assistant (HACS)
I’ve published a Home Assistant integration for Golmar G2Call+ video door stations.
What it does: you sign in once with your Golmar account; it discovers your panels automatically and creates an open‑door button per door/lock (as proper devices/entities). After setup it runs 100% locally on your LAN — the cloud is only touched at setup and a monthly key refresh. Use the buttons in dashboards, automations and Siri Shortcuts like any other button. English / French / Spanish.
Requirements: a Wi‑Fi‑connected Golmar monitor set up in G2Call+ and on the same LAN as Home Assistant (bus‑only monitors won’t work). Tested/confirmed on ART7W‑G2+; the ART 7W and SOUL Wi‑Fi families are likely candidates — reports welcome.
▎ Install (HACS): for now add it as a Custom repository → GitHub - totoantibes/golmar-quvii-ha: Open your Golmar (and other Quvii) video door stations from Home Assistant — one account login, auto-discovered panels, fully local control. · GitHub (category: Integration). A PR to the HACS default store is open, so search‑and‑install should follow once it’s merged.
:warning: Security: anyone on your LAN who has the key can open the doors — there’s no per‑user check at the door, and HA holds the key. Keep it on a trusted, segmented network and never expose the panel or HA to the internet. Details in the README.
Golmar is built on the Quvii platform, so other Quvii‑based intercom brands may work by entering their App ID / OEM ID (advanced fields) — testers and PRs very welcome. Community project, not affiliated with Golmar or Quvii.
Repo & docs: GitHub - totoantibes/golmar-quvii-ha: Open your Golmar (and other Quvii) video door stations from Home Assistant — one account login, auto-discovered panels, fully local control. · GitHub
Thanks for this! Works well!
Out of curiosity though, is there any chance this could be developed into a more fully featured integration? Like fetching video and audio from the doorbell? Or ring events? I’d be willing to help out any way I can, with my limited skills!
thanks for the feedback. these features would require a cloud based function (reproduce, reverse engineer what the app does). so not likely.
Hi, this was the integration I was waiting for years! Thank you very much!
I installed it the day was released and everything was great until today. It says “unavailable”. I deleted my hub and recreated it but still says it’s unavailable. Maybe I did something wrong.
i created a new release a few days back to include other doors or panels. did you try to reinstall/ upgrade to the newer version of the integration?
Hi, yes, I’ve updated to the second version available (v0.3.0)
Hi, the entities became available again after upgrading to os 2026.8.0
