I resolved this issue by matching the cases. filename and extension seem to be case-sensitive. So I renamed the file to google_service_account.json and it gets detected with the following in config.yaml:
google_assistant:
project_id: —
service_account: !include /config/google_service_account.json
I had this issue. It’s because I put the path to the service account file on a new line, it worked once I put it straight after !Include with a space before the path
After a frustrating hour of troubleshooting, I determined my “.json” was lowercase, and needed to be uppercase. Instantly resolved my issue. I then look back to close out tabs, and saw your comment haha.
This seems to be a small issue with the Google Assistant integration docs. Their example has the file extension as .JSON, but google downloads it as .json. Case sensitive.
