Update: the problem has stopped happening. My last action was to once more unlink and relink in Google assistant which I had done several times prior. However now Google has connected to my Home Assistant without any problem for 2 days. I can not think of anything else I did which may have resulted in this change. I will update if the problem returns
I am successful in setting up the Google Assistant component
and have successfully added the device to Google Home which then displays the entities exposed by my Home Assistant service. The problem is that after some time, Google Home will report that it is unable to connect to āHome Assistantā (the display name for my Google Action)Some time later I can check Google Home and the state of the entities is displayed and they can be controlled successfully.
The times between success or problem varies from a fraction of an hour to several hours.
I have tried using the Google home Android app on my phone and Chromebook and on my Google Home Hub and find they will all report either success or failure at the same time. That is, if one is successful, they all are and vice-versa.
I am running Home Assistant 0.84.6 in a Docker container in Fedora 29
I use an SSL cert from Letās Encrypt and have a static IPV4 address with my COX business service. I see no indications of network connection problems. All of my in-house services run with no problems reported.
I see no problems reported in the Home Assistant log. I do not see how to look for problem reports in my Google Action but maybe Iāve missed something as that is a very new area for me.
Any suggestions as to what to look for to diagnose and correct this problem? Anyone else see such intermittent problems with Google Assistant?
I have experienced the intermittent āIām sorry I canāt reach Home Assistantā & variations thereof and been wondering if anyone else had this issue. It can happen once or twice in a row then the second or third attempt will work. Itās annoying having to say the same command two or three times.
I think youāre right. I just got āIt looks like Home Assistant is unavailable right now.ā when trying to turn off my landing light. Saying the same command straight away again had it turned off virtually instantly.
Maybe itās this Australian internet, or the Pi3 canāt respond fast enough each & every time for Googleās liking, but Iāll have to keep searching for the reason it seems.
I find maybe 1 in 20 or less commands I get the no comprehende message and have to repeat itā¦ could be misunderstanding me or who knowsā¦ we certainly have good stable internet.
wellā¦ I believe I also got hit with a similar problem where my google home somehow intermittently canāt play my cuckoo clock perfectly especially when it goes beyond 9 oāclock. Any solutions?
Iāve had exactly the same issue with intermittent āproject name seems to be unavailable right nowā ever since using Google home with HA, and figured it was something to do with my internetā¦ glad itās not just me!
Did anyone ever find a solution? - If there are any Devs around, what can we do to help diagnose this problem?
Anyone ever get to the bottom of this issue ? - Iām still seeing it randomlyā¦ just last night, I asked google to turn off the light, nothing happened and then a few seconds later got the āsorry, HA smart home seems to be unavailable right nowā¦ā
I asked a second time, and the light instantly went off!!
