Hello, I am trying to setup google assistant with the new Auth. I followed the instructions on https://www.home-assistant.io/components/google_assistant/ but when I go to add a device from my google app on my phone the auth call the api/google_assistant/auth returns a 404.
Under Create an Action , under the build section, modify Add fulfillment URL to https://[YOUR HOME ASSISTANT URL:PORT]/api/google_assistant , where [YOUR HOME ASSISTANT URL:PORT] is the domain / IP address and the port under which your Home Assistant instance is reachable.
