Google Assistant Local SDK - Local Fulfillment
something is not right…
it was working, did a HA restart, then i saw some webhooks , probably the google devices that were not able to connect to nginx, those are the rejected promises below
then it switched back to cloud it seems
and then finally when i turn on a light, it doesnt work anymore, not with local or cloud
got a google message like :
Looks like HA is not avaible at this time
verry frustating
i think it doesnt connect anymore, maybe i need to wait again for tha max 30 min after a restart of HA
omg, rebooted HA, and devices, now the verification issue is back
what a mess!! this script / local sdk is not ready yet
my recommendation. Leave it alone. See if it fixes itself.
yeah, its reverted to cloud, lets wait indeed
how is it going on your side?
btw, is that marcusds guy, the one that updated the js file also on community or discord? maybe he can help us?
created issue thread here:
Mine is fine. Been working through restarts.
It has something to do with Name, the name field cleared the verification issue before, not sure why it doesn’t work anymore after a restart… Allthough I have setup it with a *
What is your Name on HA? And how did you setup on the actions page?
Could the name be this we set for the Home Assistant Instance ?
Where we also set measurement units and location for example.
Yes, the Name field is indeed important, not sure why…
That is why it is important. I am not sure if the home assistant “Name” (configuration pages) influences the name. I’d guess it does and you’d need to make sure it is finding it.
If you do a mdns scan you can see the names. Mine is just 'Home" so no issues.
I’m guessing if you have multiple HAs, you’d need them different for the scan to know which one? But regardless, you should make sure the Name in google actions matches your name in a mdns scan. However that is derived.
Yes and that’s why I wanted to suggest to fill the name field with the Home Assistant instance name, which is returned by a mdns scan.
I’m actually wondering if the recommendation for
'.*\._home-assistant\._tcp\.local'
is incorrect. I am wondering if it should be ‘Home’ in my case or a regex for it. I dont want to touch it as its not broken. :upside_down_face:
Looks correct though. :thinking:
I have used the * before, it works for me, untill a reboot… Gonna rename my instance later and test again
avahi-browse --all --ignore-local -p  --terminate  | grep ho
+;wlp58s0;IPv4;Home;_home-assistant._tcp;local
Personally, based on my data above, I don’t think its defined incorrectly. If my instance is ‘Home’. I would have thought:
Home\._home-assistant\._tcp\.local
based on their example:
my-device-[0-9]{4}\._http\._tcp\.local
how do you have it now setup on the actions page?
If it stops working at any point, i’m going to use the one I believe it should be.
I have it now configured as :
.Home\._home-assistant\._tcp\.local
homeassistant:
  internal_url: !secret internal_url
  external_url: !secret external_url
restarted everything, no more verification issue, but also, the script isnt activated, the google device doesnt connect to HA
Are you using the original script? or the modifled .js file?
The latest one. No modifications on my side
