Google Assistant Local SDK - Local Fulfillment
Hi everyone, I’m also struggling with this.
Debugging the app.js device i noticed that the devices in the device list have the customData property empty.
So i checked the homeassistant source code and found this.
I guess that means the local fulfillment feature is not available if you are using https?
I tried changing the source code, commenting these lines, in order to force the enable of the local sdk, and after that the customData property was filled with the right values (but i have other issues now: “Did not receive HTTP response” debugging the app.js)
Did you manage to make it works with https? or only with http?
It’s strange, as soon I restart my HA, i immediately have an unregistered websocket coming in, and it doesn’t try to reconnect anymore
No, only works if your local instance runs with http
It comes down to certificates. https requires the googles talk to HA with a certificate using the UID.local domain. That will never work under the current architecture. The only way to really do that, would be to have a seperate http server running for mDNS entries and for HA serving a mdns broadcast with a public domain name which can have a valid cert.
Thanks for the clarifications.
I made it works keeping the ssl enabled, in a very ugly way.
if you are interested (it’s a bit hackish):
  • set up apache as a http-to-https proxy
  • set the internal URL in homeassistant to point to the proxy
  • edited the app.js and the components/google_assistant/helpers.py to ignore the SSL and use the proxy http://proxy_host:port
It seems to work fine, let’s see if it lasts
That’s not really ssl enabled though? You’re using a http port for the google hooks. I’m not sue how that is different than just setting non-ssl for the internal port.
Well, that’s because I didn’t know homeassistant can manage 2 different port for internal and external, one with https and one http :thinking: how can i do that?
The external url would be https on some port. The internal would be http on some port. I don’t really use my internal url for anything and instead use NATLOOPBACK and use the external URL for 99% of the use cases. The one that can’t is this local fullfillment.
I use a nginx proxy (nginx proxy manager) for the https portion and leave the internal/http one as is. You don’t want to set the ssl within the HA config.
Ok but I don’t think you can set homeassistant to work with 2 ports, right?
I have homeassistant directly exposed on the internet right now, so it is with SSL enabled and apache provide for the internal http.
I’ll try to espose apache with SSL on the internet as proxy for homeassistant and disable SSL on homeassistant. I guess is that what you mean?
That’s exactly right. The ‘nginx proxy manager’ by Frenk is incredibly easy to do just that. Just create a letsencrypt cert and a proxy host and done. All within the tool itself. It integrates will with the supervisor.
I installed the homeassistant core, so no supervisor. My raspberry also run other stuff, anyway I’ll switch to the no SSL homeassistant with apache as proxy
i can use ‘via local’ just fine… Untill i reboot HA , then the local stuff doesnt work anymore
i always get unverified webhooks in logbook, with device verification failed…
To resolve, i always need to “sync my devices” command, then restart HA again, and then its working again… untill the next HA restart
any idea?
You can use the Assistant Relay addon to send commands to your Google Home devices and could therefore have it run ‘sync my devices’ whenever it boots? Not ideal but it might work!
Seems there is also a service, I use that now in an automation :slight_smile:
Is it possible to skip mdns, and provide ip for HA instance ? I’ve got HA on different subnetwork and inside vlan, and mdns doesnt work, without some bridge / relay solution afaik.
I read there were another solution within using UDP for local actions.
But it would imply rewrite the local action support and I don’t know if it could make it less strange.
Where do you see that info?
In the Google developers doc about local fulfillment.
There are three possible implementations:
  • MDNS, the one which is implemented in Home Assistant
  • UPNP
  • UDP
But I don’t know if it could change anything.
my local stuff breaks, when i dont do a sync 4 times a day, created an automation for it
in this google_assistant file, in the .storage folder, i need there the agent id
if its not there, local fails
when i do a sync, it fills up with an agent id, if i the reboot the devices, it works again, and dont have verification failed issues
not using nabucasa here:
    "version": 1,
    "minor_version": 1,
    "key": "google_assistant",
    "data": {
        "agent_user_ids": {
            "xxxx": {
                "local_webhook_id": "xxxxxx"
I don’t think UDP goes across vlans by default. UPNP goes across networks, but not sure if it does across vlans.
