Google Assistant - New Devices
Hi
I seem to have problem with new devices being detected in Home Assistant.
They won’t magically turn up. You have to sync, which requires that you’ve set up the api key. See the documentation for details on troubleshooting.
If your setup is correct, simply ask your Google Assistant to “sync my devices”, and new devices should pop up, asking you to set rooms for them.
I get “An error occurred while syncing my test app” I am still able to control my existing set of light/devices.
I have it setup, my existing devices is working fine. It just i recently brought new lights.
View your logs, you certainly have an error message somewhere. Then follow links provided by Tinkerer to fix your issue (most probably relink your account)
