I think you can safely take it out (
google_assistant_name) , and just use friendly_name and aliases
I followed your suggestion but still canât link back
it says in the GH app, "Succesfully linked the [test] CLaudio app âŚ
but no device is added ⌠???
I started from scracth (created new app in developer console amd all the rest) ⌠still the same result ⌠linking succesfully but no device showing.
Did it change something?
google_assistant:
project_id: hassio2018
client_id: cccccccccccccccc
access_token: ccccccccccccccc
expose_by_default: false
api_key: ccccccccccccccc
exposed_domains:
- switch
- light
- script
- media_player
- scene
- group
Just thought I would share my recent experience with google assistant linking.
When I first set it all up (as per the component docs) it worked, though it added everything in my Home Assistant config into Google Assistant. I tried the request_sync command but that was returning the request_sync request failed: 400
error mentioned on the docs.
I ended up setting everything up a couple of times before it was working correctly, I set expose_by_default: false
and for the devices I want to add to Alexa and Google I use the customize.yaml
file e.g.
light.yaml
- platform: rfxtrx
automatic_add: False
devices:
710010041030000:
710010041040000:
customize.yaml
light.dining_lamp:
friendly_name: Dining Lamp
google_assistant: true
emulated_hue_hidden: false
emulated_hue_name: "Dining Lamp"
light.lava_lamp:
friendly_name: Lava Lamp
emulated_hue_name: "Lava Lamp"
google_assistant_type: light
I am not sure this is the correct way to do it as I am relatively new to hass (a couple of weeks) but have been fiddling with home automation, voice control (custom Alexa Skills) and OpenHAB for a couple of years.
Today I wanted to add another socket to turn on the christmas tree lights.
switches.yaml
- platform: rfxtrx
devices:
710010041010000:
customize.yaml
switch.socket_01:
google_assistant_type: switch
friendly_name: Christmas tree
emulated_hue_name: "Christmas tree"
Worked in Hass but it wasnât showing up in the Google Home app.
Reluctant to unlink and link my account again (and having to assign all the devices to rooms again) I tried calling the request_sync
service again. It didnât work, all I got was the same 400 error as before.
So I unlinked and expected to see the account [test] House Name
under Add new but it wasnât there. I waited a few min, but still nothing.
I then found this thread and was about to try renaming things to see if that triggered anything. Before I did I went to https://console.actions.google.com to see if there was anything there that was obviously wrong. I clicked Test draft and within a few seconds it popped back up on my phone under Add new. I linked accounts and the devices were there including the new âChristmas Treeâ switch.
Out of curiosity I tried the request_sync
call again, went to the log expecting to see the error, and whilst there was an error it was timed 10 minutes before. Which was a first, so just to be sure I clicked it again and still no error.
I then changed to change the name (using the web ui > Configuration > Customization) from âChristmas treeâ to âChristmas lightsâ, saved it, called the request_sync
service and in a few seconds the change appeared on my phone (after doing the usual âpull down to refreshâ).
Woohoo.
I then tried changing the name using the yaml file
customize.yaml
switch.socket_01:
friendly_name: Christmas fairy lights
Saved the file, clicked each of the Reload buttons (Core, Groups, Automation, Scripts) and nothing (worth noting that I didnât have to restart Hass). I then looked in the web ui customization bit again, and the name was appearing as âChristmas fairy lightsâ but my phone wasnât picking up the new name.
Of course, I had forgotten to call request_sync
, after I made the call again, it still wasnât appearing with the new name in the yaml file.
Even though I could see the new name âChristmas fairy lightsâ in the web ui (so it must have read the file correctly) I had to also click Save (even though I hadnât made any changes in the web ui) in order for it to work. After another request_sync
, within a few seconds it was appearing on my phone as âchristmas fairy lightsâ. Maybe the last step of having to click Save would not have been required if I had restarted Hass,
Conclusion:
It seems it does still work as intended (i am using hass.io v60) without having to change the name with letters or numbers or adding aliases.
As the above was mainly about changing the name because the adding of the device was achieved initially by unlinking the account, I also tried adding some new devices. Edited the config files, saved them, restarted Hass, checked phone a few times and saw no new devices were appearing, called request_sync
and within a new seconds (and a refresh) the new devices appeared on my phone.
Yay
edit: I thought I would provide my google_assistant config in case it helps
google_assistant:
project_id: something-123456
client_id: random80characters
access_token: random80characters
api_key: XXX
agent_user_id: [email protected]
As per the note at the bottom of the docs I created the project in the Google Console first, then when creating an Action I used the project-id already set (it appeared in a dropdown when I went to give it a name)
Is this still an issue? I had it all working, but since the latest hassio I got errors on the input_boolean. So I tried to unlink and link again, but unfortunately I cannot get it linked back again. I get the âtest appâ in the google home app, but after trying to link it gives the error âsomething went wrong, try againâ.
I looked in the logs, but there is no error, I rebuild the app and still get the same message. I tried to expose only one light, or expose everything, still no success.
Anybody got advice? I donât know what else I can do or check to find out what the problem is.
Go through the config all again. I think Google added something⌠I had a similar problem and just went through it all again and got it working.
apart from input_boolean. you also have to remove type:
Hey all.
Just a quick note of how i got it finding my devices again without having to add aliases to all my devices.
- I went to https://console.actions.google.com/ and selected my project
- Clicked on âTest Draftâ
- On the next page, top right click the reset icon.
- When I then tried to relink in the Google Home app, all devices showed up.
Iâm not sure if this is a coincidence or if it did in fact reset the project, but its worth a try.
@SuperSean, thanks for this. This worked for me when my test app no longer showed up in Google Home after unlinking.
