Hi there,
I’ve just set up Google Assistant and I can see that Scenes are exported and seemingly assigned to a Room within Google Home (i.e. they show as “Room Name • Name of Scene” within the Routines section).
Scripts, however, only show as “Name of Scene” even if they have an area defined in HA.
The reaosn is that I want to be able to trigger a script with the same invocations in different rooms and have different things happen. For example: “activate get ready for bed” should do different things based on which room it was said in. I created two scripts with the same name in different areas but this just resulted in both of them being triggered at the same time by Google.
Any thoughts?
Adam
