Google Assistant with template commands
Following the recent changes to the IFTTT google assistant integration, is there a way to use home assistant, perhaps with node red to create automations with template command such as:
“Tell evernote xxx” - Creates a note with xxx
We use assistant relay for most stuff like this, can use it to send commands to google assistant via home assistant. It’s not been maintained for many years but still works well.
However (I am not sure if it’s related to personal results setting) I can’t for example use it to add something to my google keep and I assume this is because it doesn’t technically know who is sending the request.
