is there any known issue with the Google Calendar integration? After Update to 2023.4 the calendar is shown as “off” The connection is ok and I reconfigured it but it is the same. Any ideas?
Mine is working
Not sure but somethings has changed. In general it is working, only the Abfallkalender is not working. It is within the same Account as the other calendars and I can see it also on my Android devices.
it seems to be an issue with the calendar integration
File "<string>", line 11, in __init__
File "/usr/src/homeassistant/homeassistant/components/calendar/__init__.py", line 345, in __post_init__
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Failed to validate CalendarEvent: Expected positive event duration (2023-04-12 06:00:00+02:00, 2023-04-12 06:00:00+02:00)
The answer is in the release notes and blog post.
…thanks, but I do not understand what you mean, I don´t see any hints to my issue in the release notes.
For other folks that come across this, we’re fixing in Google Calendar integration issue after Core-Update to 2023.4 · Issue #90952 · home-assistant/core · GitHub and targeting a patch release.
Your event has the same start and end.
The
calendar.create_event
service now enforces that start and end dates are exclusive. This has always been part of the specification but was not clearly documented and enforced.
EDIT: I assumed that was your own calendar. I have no idea what that calender is otherwise and it wasn’t stated it was third-party or something. Regardless, the issue is with the event’s times.
Hi all,
yes, I noticed this, that it has the same start and end-date, but it is like it is, I cannot change it, because it is an Subscription. The Fix iwhich has been created s not working and I get errors again.
Logger: homeassistant
Source: components/calendar/__init__.py:345
First occurred: 08:57:06 (3 occurrences)
Last logged: 09:27:06
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 229, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 355, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 353, in _exec
v = func(path, v)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/components/calendar/__init__.py", line 129, in validate
raise vol.Invalid(f"Expected positive event duration ({start}, {end})")
voluptuous.error.Invalid: Expected positive event duration (2023-04-12 06:00:00+02:00, 2023-04-12 06:00:00+02:00)
File "/usr/src/homeassistant/homeassistant/components/calendar/__init__.py", line 343, in __post_init__
CALENDAR_EVENT_SCHEMA(dataclasses.asdict(self, dict_factory=skip_none))
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 276, in __call__
raise er.MultipleInvalid([e])
voluptuous.error.MultipleInvalid: Expected positive event duration (2023-04-12 06:00:00+02:00, 2023-04-12 06:00:00+02:00)
File "/usr/src/homeassistant/homeassistant/components/google/calendar.py", line 439, in refresh
await self.coordinator.async_request_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 200, in async_request_refresh
await self._debounced_refresh.async_call()
File "/usr/src/homeassistant/homeassistant/helpers/debounce.py", line 89, in async_call
await task
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 226, in async_refresh
await self._async_refresh(log_failures=True)
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 341, in _async_refresh
self.async_update_listeners()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 142, in async_update_listeners
update_callback()
File "/usr/src/homeassistant/homeassistant/components/google/calendar.py", line 475, in _handle_coordinator_update
self._apply_coordinator_update()
File "/usr/src/homeassistant/homeassistant/components/google/calendar.py", line 465, in _apply_coordinator_update
self._event = _get_calendar_event(api_event)
File "/usr/src/homeassistant/homeassistant/components/google/calendar.py", line 550, in _get_calendar_event
return CalendarEvent(
Please find also the ical from the vendor.
BEGIN:VCALENDAR
VERSION:2.0
PRODID:www.gwa-abfallkalender.de
X-WR-CALNAME:GWA Abfallkalender 2023
X-PUBLISHED-TTL:P1W
BEGIN:VEVENT
UID:642fc7547acdb
DTSTART;TZID=Europe/Berlin:20230103T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230103T060000
SUMMARY:Wertstofftonne
CLASS:PUBLIC
DTSTAMP:20230407T073340Z
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Wertstofftonne
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547acf6
DTSTART;TZID=Europe/Berlin:20230105T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230105T060000
SUMMARY:Restmüll 2-wchtl.
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Restmüll 2-wchtl.
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad0e
DTSTART;TZID=Europe/Berlin:20230109T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230109T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Biotonne
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad22
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Weihnachtsbaum
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Weihnachtsbaum
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad36
DTSTART;TZID=Europe/Berlin:20230117T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230117T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad48
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Papiertonne
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad5a
DTSTART;TZID=Europe/Berlin:20230119T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230119T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad6b
DTSTART;TZID=Europe/Berlin:20230123T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230123T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad7d
DTSTART;TZID=Europe/Berlin:20230131T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230131T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ad90
DTSTART;TZID=Europe/Berlin:20230202T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230202T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ada3
DTSTART;TZID=Europe/Berlin:20230206T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230206T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547adb5
DTSTART;TZID=Europe/Berlin:20230214T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230214T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547adc7
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547add8
DTSTART;TZID=Europe/Berlin:20230216T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230216T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547adea
DTSTART;TZID=Europe/Berlin:20230220T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230220T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547adfc
DTSTART;TZID=Europe/Berlin:20230228T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230228T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae17
DTSTART;TZID=Europe/Berlin:20230302T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230302T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae2d
DTSTART;TZID=Europe/Berlin:20230306T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230306T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae40
DTSTART;TZID=Europe/Berlin:20230314T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230314T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae52
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae63
DTSTART;TZID=Europe/Berlin:20230316T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230316T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae75
DTSTART;TZID=Europe/Berlin:20230320T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230320T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae87
DTSTART;TZID=Europe/Berlin:20230325T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230325T060000
SUMMARY:Pfadfinder
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Pfadfinder
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547ae98
DTSTART;TZID=Europe/Berlin:20230328T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230328T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547aeaa
DTSTART;TZID=Europe/Berlin:20230330T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230330T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547aebc
DTSTART;TZID=Europe/Berlin:20230403T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230403T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547aeda
DTSTART;TZID=Europe/Berlin:20230412T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230412T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547aeec
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547aeff
DTSTART;TZID=Europe/Berlin:20230414T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230414T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af10
DTSTART;TZID=Europe/Berlin:20230417T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230417T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af22
DTSTART;TZID=Europe/Berlin:20230425T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230425T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af34
DTSTART;TZID=Europe/Berlin:20230427T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230427T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af48
DTSTART;TZID=Europe/Berlin:20230502T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230502T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af5b
DTSTART;TZID=Europe/Berlin:20230509T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230509T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af6d
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af7f
DTSTART;TZID=Europe/Berlin:20230511T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230511T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547af92
DTSTART;TZID=Europe/Berlin:20230515T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230515T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547afa4
DTSTART;TZID=Europe/Berlin:20230523T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230523T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547afb6
DTSTART;TZID=Europe/Berlin:20230525T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230525T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547afc7
DTSTART;TZID=Europe/Berlin:20230530T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230530T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547afdc
DTSTART;TZID=Europe/Berlin:20230606T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230606T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547afed
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b000
DTSTART;TZID=Europe/Berlin:20230609T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230609T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b012
DTSTART;TZID=Europe/Berlin:20230612T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230612T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b024
DTSTART;TZID=Europe/Berlin:20230620T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230620T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b035
DTSTART;TZID=Europe/Berlin:20230622T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230622T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b04a
DTSTART;TZID=Europe/Berlin:20230626T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230626T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b05c
DTSTART;TZID=Europe/Berlin:20230704T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230704T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b06e
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b080
DTSTART;TZID=Europe/Berlin:20230706T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230706T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b092
DTSTART;TZID=Europe/Berlin:20230710T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230710T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b0a4
DTSTART;TZID=Europe/Berlin:20230718T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230718T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b0b6
DTSTART;TZID=Europe/Berlin:20230720T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230720T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b0c7
DTSTART;TZID=Europe/Berlin:20230724T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230724T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b0d9
DTSTART;TZID=Europe/Berlin:20230801T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230801T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b0ea
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b0fb
DTSTART;TZID=Europe/Berlin:20230803T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230803T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b10d
DTSTART;TZID=Europe/Berlin:20230807T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230807T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b11f
DTSTART;TZID=Europe/Berlin:20230815T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230815T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b131
DTSTART;TZID=Europe/Berlin:20230817T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230817T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b142
DTSTART;TZID=Europe/Berlin:20230821T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230821T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b154
DTSTART;TZID=Europe/Berlin:20230829T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230829T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b165
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b176
DTSTART;TZID=Europe/Berlin:20230831T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230831T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b18b
DTSTART;TZID=Europe/Berlin:20230904T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230904T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b19e
DTSTART;TZID=Europe/Berlin:20230909T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230909T060000
SUMMARY:Pfadfinder
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b1b0
DTSTART;TZID=Europe/Berlin:20230912T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230912T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b1c3
DTSTART;TZID=Europe/Berlin:20230914T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230914T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b1d5
DTSTART;TZID=Europe/Berlin:20230918T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230918T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b1e7
DTSTART;TZID=Europe/Berlin:20230926T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230926T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b1f8
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b20a
DTSTART;TZID=Europe/Berlin:20230928T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20230928T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b21c
DTSTART;TZID=Europe/Berlin:20231002T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231002T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b22e
DTSTART;TZID=Europe/Berlin:20231010T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231010T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b240
DTSTART;TZID=Europe/Berlin:20231012T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231012T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b251
DTSTART;TZID=Europe/Berlin:20231016T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231016T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b263
DTSTART;TZID=Europe/Berlin:20231024T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231024T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b275
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b286
DTSTART;TZID=Europe/Berlin:20231026T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231026T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b298
DTSTART;TZID=Europe/Berlin:20231030T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231030T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b2aa
DTSTART;TZID=Europe/Berlin:20231107T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231107T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b2bd
DTSTART;TZID=Europe/Berlin:20231109T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231109T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b2cf
DTSTART;TZID=Europe/Berlin:20231113T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231113T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b2e4
DTSTART;TZID=Europe/Berlin:20231121T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231121T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b2f6
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b307
DTSTART;TZID=Europe/Berlin:20231123T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231123T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b319
DTSTART;TZID=Europe/Berlin:20231127T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231127T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b32e
DTSTART;TZID=Europe/Berlin:20231205T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231205T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b341
DTSTART;TZID=Europe/Berlin:20231207T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231207T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b353
DTSTART;TZID=Europe/Berlin:20231211T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231211T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b366
DTSTART;TZID=Europe/Berlin:20231219T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231219T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b377
SEQUENCE:0
TRANSP:OPAQUE
SUMMARY:Papiertonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b38a
DTSTART;TZID=Europe/Berlin:20231221T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231221T060000
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:642fc7547b39b
DTSTART;TZID=Europe/Berlin:20231223T060000
SEQUENCE:0
TRANSP:OPAQUE
DTEND;TZID=Europe/Berlin:20231223T060000
SUMMARY:Biotonne
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
END:VCALENDAR
thank you very much for the fix, it is working again in 2023.4.2
Spartacus.
