I’ve added a calendar to my Google Calendar, but it doesn’t sync to Home Assistant Google Calendar integration. I was expecting the new calendar to be a new entity. I’ve tried to reauthenticate, but that didn’t help. I have restarted Home Assistant, but that didn’t help. Any ideas?
Depends on what you mean by ‘added a calendar’. What did you do exactly? I have multiple calendars syncing just fine.
I have also multiple calendars syncing fine. However, today I added a new calendar on calendar.google.com - and it doesn’t show up in the Calendar Integration.
Meaning it does not check for new calendars after adding? That would mean removing the integration and adding it again might help.
That didn’t help.
The new calendar syncs fine to Google Calendar app on my phone, but not to Google Calendar Integration in Home Assistant.
It seems I’m missing something here. Is there maby a extra step?
I solved it. The new calendar had a name that I didin’t expect. I have a lot of calendars and I didn’t see the new calendar since I was looking for another name.
